[postgis-users] Any available Postgis 2.1 rpm for Opensuse?
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jan 8 16:11:32 PST 2014
Hi Marco,
So by "11.3" you mean SLES 11 SP3.
You correctly found Bruno's OBS branch, this is to be merged into
Application:Geo soon.
Yes it is doable to build PostgreSQL 9.3 + PostGIS 2.1 packages under SLES.
SLES is an enterprise product and supports a specific version of
Postgres in the official repositories. So usually packagers support the
distribution's base version, in this case 9.1.
The good thing with Open Build Service is that any community member can
create new packages and publish them to the users.
Best,
Angelos
On 01/09/2014 12:10 AM, Marco wrote:
> Hi Angelos,
> Thank you for replying me.
> Unfortunately, the product I am working on is restricted to work only on
> SUSE 11.3 or 11.2. :( I am trying to set up postgresql 9.3 with PostGIS
> 2.1, Since Postgresql9.3 only support postGIS 2.1 or higher.
> Is it doable to build an rpm from the PostGIS 2.1 source file?
> and I found an PostGIS 2.1 rpm for SUSE 11.3 under the Geo repo
> http://download.opensuse.org/repositories/home:/bruno_friedmann:/branches:/Application:/Geo/SLE_11_SP3/x86_64/
> however, it created an postgresql91 directory under /usr/share/ after the
> installation. does that mean this rpm is bundled to Postgresql91, and
> doesn't support Postgresql 9.3 at all?
> Thank you,
> Marco
> On Wed, Jan 8, 2014 at 12:00 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
>> On 01/08/2014 07:38 PM, Marco wrote:
>> Hello,
>> I have been searching Postgis 2.1 rpm for SUSE 11.3. Unfortunately, I
>> haven't found one yet.
>> I wonder whether anyone find one or not. The last solution for me is to
>> build rpm from the binary source, which I have no experience on that.
>> is there any other better approach? or if anyone tried to build rpm from
>> source and what possible issues would encounter?
>> Thank you
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Hi Marco.
>> There is a PostGIS 2.1.1 rpm for openSUSE through OBS:
>> http://software.opensuse.org/package/postgis21
>> openSUSE 11.3 is EOL for years now. The currently supported versions are
>> 12.2, 12.3 and 13.1.
>> This is in the process to be ported to official Application:Geo repository
>> which now has PostGIS 2.0.4
>> Cheers,
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athenshttp://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140109/02c98777/attachment.html>
