[postgis-users] Any available Postgis 2.1 rpm for Opensuse?
Marco
marco91414 at gmail.com
Wed Jan 8 16:29:58 PST 2014
Hi Angelos,
Thank you again for helping me.
is there any instruction for building packages? or any concern and issues I
need to beware of?
Thank you,
Marco
On Wed, Jan 8, 2014 at 4:11 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
> Hi Marco,
> So by "11.3" you mean SLES 11 SP3.
> You correctly found Bruno's OBS branch, this is to be merged into
> Application:Geo soon.
> Yes it is doable to build PostgreSQL 9.3 + PostGIS 2.1 packages under SLES.
> SLES is an enterprise product and supports a specific version of Postgres
> in the official repositories. So usually packagers support the
> distribution's base version, in this case 9.1.
> The good thing with Open Build Service is that any community member can
> create new packages and publish them to the users.
> Best,
> Angelos
> On 01/09/2014 12:10 AM, Marco wrote:
> Hi Angelos,
> Thank you for replying me.
> Unfortunately, the product I am working on is restricted to work only on
> SUSE 11.3 or 11.2. :( I am trying to set up postgresql 9.3 with PostGIS
> 2.1, Since Postgresql9.3 only support postGIS 2.1 or higher.
> Is it doable to build an rpm from the PostGIS 2.1 source file?
> and I found an PostGIS 2.1 rpm for SUSE 11.3 under the Geo repohttp://download.opensuse.org/repositories/home:/bruno_friedmann:/branches:/Application:/Geo/SLE_11_SP3/x86_64/
> however, it created an postgresql91 directory under /usr/share/ after the
> installation. does that mean this rpm is bundled to Postgresql91, and
> doesn't support Postgresql 9.3 at all?
> Thank you,
> Marco
> On Wed, Jan 8, 2014 at 12:00 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com> <gcpp.kalxas at gmail.com>wrote:
> On 01/08/2014 07:38 PM, Marco wrote:
> Hello,
> I have been searching Postgis 2.1 rpm for SUSE 11.3. Unfortunately, I
> haven't found one yet.
> I wonder whether anyone find one or not. The last solution for me is to
> build rpm from the binary source, which I have no experience on that.
> is there any other better approach? or if anyone tried to build rpm from
> source and what possible issues would encounter?
> Thank you
> ______________________________
> _________________
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Hi Marco.
> There is a PostGIS 2.1.1 rpm for openSUSE through OBS:http://software.opensuse.org/package/postgis21
> openSUSE 11.3 is EOL for years now. The currently supported versions are
> 12.2, 12.3 and 13.1.
> This is in the process to be ported to official Application:Geo repository
> which now has PostGIS 2.0.4
> Cheers,
> Angelos
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athenshttp://users.ntua.gr/tzotsos
> Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140108/23b7e4db/attachment.html>
