[postgis-users] Any available Postgis 2.1 rpm for Opensuse?
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jan 8 16:43:39 PST 2014
You are welcome.
http://en.opensuse.org/openSUSE:Packaging_guidelines
Best,
Angelos
On 01/09/2014 02:29 AM, Marco wrote:
> Hi Angelos,
> Thank you again for helping me.
> is there any instruction for building packages? or any concern and issues I
> need to beware of?
> Thank you,
> Marco
> On Wed, Jan 8, 2014 at 4:11 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
>> Hi Marco,
>> So by "11.3" you mean SLES 11 SP3.
>> You correctly found Bruno's OBS branch, this is to be merged into
>> Application:Geo soon.
>> Yes it is doable to build PostgreSQL 9.3 + PostGIS 2.1 packages under SLES.
>> SLES is an enterprise product and supports a specific version of Postgres
>> in the official repositories. So usually packagers support the
>> distribution's base version, in this case 9.1.
>> The good thing with Open Build Service is that any community member can
>> create new packages and publish them to the users.
>> Best,
>> Angelos
>> On 01/09/2014 12:10 AM, Marco wrote:
>> Hi Angelos,
>> Thank you for replying me.
>> Unfortunately, the product I am working on is restricted to work only on
>> SUSE 11.3 or 11.2. :( I am trying to set up postgresql 9.3 with PostGIS
>> 2.1, Since Postgresql9.3 only support postGIS 2.1 or higher.
>> Is it doable to build an rpm from the PostGIS 2.1 source file?
>> and I found an PostGIS 2.1 rpm for SUSE 11.3 under the Geo repohttp://download.opensuse.org/repositories/home:/bruno_friedmann:/branches:/Application:/Geo/SLE_11_SP3/x86_64/
>> however, it created an postgresql91 directory under /usr/share/ after the
>> installation. does that mean this rpm is bundled to Postgresql91, and
>> doesn't support Postgresql 9.3 at all?
>> Thank you,
>> Marco
>> On Wed, Jan 8, 2014 at 12:00 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com> <gcpp.kalxas at gmail.com>wrote:
>> On 01/08/2014 07:38 PM, Marco wrote:
>> Hello,
>> I have been searching Postgis 2.1 rpm for SUSE 11.3. Unfortunately, I
>> haven't found one yet.
>> I wonder whether anyone find one or not. The last solution for me is to
>> build rpm from the binary source, which I have no experience on that.
>> is there any other better approach? or if anyone tried to build rpm from
>> source and what possible issues would encounter?
>> Thank you
>> ______________________________
>> _________________
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Hi Marco.
>> There is a PostGIS 2.1.1 rpm for openSUSE through OBS:http://software.opensuse.org/package/postgis21
>> openSUSE 11.3 is EOL for years now. The currently supported versions are
>> 12.2, 12.3 and 13.1.
>> This is in the process to be ported to official Application:Geo repository
>> which now has PostGIS 2.0.4
>> Cheers,
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athenshttp://users.ntua.gr/tzotsos
>> Angelos Tzotsos
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140109/a48f8fc4/attachment.html>
