[postgis-users] postgis topology
Ludovic Granjon ludovic.granjon at u-bourgogne.fr
Wed Jan 15 01:33:09 PST 2014
Hello (Bonjour Christophe)
I don't use french cadastre, only specific archaelogical data.
Thanks for this, I try but, I don't realy understand how worked
topogeo_addpolygon.
If I do :
CREATE EXTENSION postgis;
CREATE EXTENSION postgis_topology;
SET search_path = topology,public;
I import my layer with QGIS
SELECT topology.CreateTopology('ec_topo', 27572);
SELECT
topology.AddTopoGeometryColumn('ec_topo','public','ec','topo_geom','POLYGON');
DO $$DECLARE r record;
BEGIN
   FOR r IN SELECT * FROM ec LOOP
     BEGIN
     SELECT topology.TopoGeo_AddPolygon('ec_topo',st_geometryn(r.geom,1),1);
     EXCEPTION
       WHEN OTHERS THEN
         RAISE WARNING 'Loading of record % failed: %', r.id, SQLERRM;
     END;
   END LOOP;
END$$;
I have :
ATTENTION:  Loading of record 1 failed: la requête n'a pas de
destination pour les données résultantes
I don't know where I'm wrong
If you have an idea
Thanks
Regards
Ludovic
PS : (si j'avais sur que c'était toi qui répondrait, j'aurai écrit sur
nos forums francophone ;-) )
Le 15/01/2014 08:25, Christophe Vergon a écrit :
> Hello, (bonjour)
> When you udpdate a topology by using a SET statement if a polygon
> intersect an other you will have this error.
> If you want to create a topology from polygons try to use the
> topogeo_addpolygon function, the intersection between two polygons
> will be a new face.
> If, as I mean, you use a french survey "cadastre" data set, it's the
> best way to do that.
> Ludovic Granjon a écrit :
>> Hi all
>> I try to import a polygon layer to postgis and build topology with
>> tolerance.
>> I try something like that
>> SELECT CreateTopology('ec_topo2', 27572);
>> SELECT AddTopoGeometryColumn('ec_topo2', 'public', 'ec', 'topogeom2',
>> 'MULTIPOLYGON');
>> UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
>> But when I do that, I have
>> ********** Erreur **********
>> ERREUR: Spatial exception - geometry intersects edge 262
>> État SQL :P0001
>> Contexte : fonction PL/pgsql « topogeo_addlinestring », ligne 124 à
>> affectation
>> SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
>> topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
>> fonction PL/pgsql « topogeo_addpolygon », ligne 24 à affectation
>> fonction PL/pgsql « totopogeom », ligne 112 à FOR sur des lignes de
>> SELECT
>> fonction PL/pgsql « totopogeom », ligne 94 à affectation
>> I try to modify the tolerance parameter but it still doesn't work
>> Have  you a solution for that ?
>> Thanks a lot
>> Regards
>> Ludovic
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/ee1fd5af/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/ee1fd5af/attachment.vcf>
