[postgis-users] postgis topology
Christophe Vergon christophevergon-girtec at orange.fr
Tue Jan 14 23:25:53 PST 2014
Hello, (bonjour)
When you udpdate a topology by using a SET statement if a polygon
intersect an other you will have this error.
If you want to create a topology from polygons try to use the
topogeo_addpolygon function, the intersection between two polygons will
be a new face.
If, as I mean, you use a french survey "cadastre" data set, it's the
best way to do that.
Ludovic Granjon a écrit :
> Hi all
> I try to import a polygon layer to postgis and build topology with
> tolerance.
> I try something like that
> SELECT CreateTopology('ec_topo2', 27572);
> SELECT AddTopoGeometryColumn('ec_topo2', 'public', 'ec', 'topogeom2',
> 'MULTIPOLYGON');
> UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
> But when I do that, I have
> ********** Erreur **********
> ERREUR: Spatial exception - geometry intersects edge 262
> État SQL :P0001
> Contexte : fonction PL/pgsql « topogeo_addlinestring », ligne 124 à
> affectation
> SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
> topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
> fonction PL/pgsql « topogeo_addpolygon », ligne 24 à affectation
> fonction PL/pgsql « totopogeom », ligne 112 à FOR sur des lignes de
> SELECT
> fonction PL/pgsql « totopogeom », ligne 94 à affectation
> I try to modify the tolerance parameter but it still doesn't work
> Have  you a solution for that ?
> Thanks a lot
> Regards
> Ludovic
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
