[postgis-users] postgis topology
Rémi Cura
remi.cura at gmail.com
Wed Jan 15 04:49:41 PST 2014
-- Function: public.rc_totopogeomwithouterrors(geometry, character varying,
integer, double precision)
-- DROP FUNCTION public.rc_totopogeomwithouterrors(geometry, character
varying, integer, double precision);
CREATE OR REPLACE FUNCTION public.rc_totopogeomwithouterrors(ageom
geometry, atopology character varying, alayer integer, atolerance double
precision DEFAULT 0)
RETURNS topogeometry AS
$BODY$
DECLARE
layer_info RECORD;
topology_info RECORD;
rec RECORD;
tg topology.TopoGeometry;
elems topology.TopoElementArray = '{{0,0}}';
sql TEXT;
typ TEXT;
tolerance FLOAT8;
BEGIN
raise notice 'ageom : %',ST_AsText(ageom);
-- Get topology information
BEGIN
SELECT *
FROM topology.topology
INTO STRICT topology_info WHERE name = atopology;
EXCEPTION
WHEN NO_DATA_FOUND THEN
RAISE EXCEPTION 'No topology with name "%" in topology.topology',
atopology;
END;
-- Get tolerance, if 0 was given
tolerance := COALESCE( NULLIF(atolerance, 0),
topology._st_mintolerance(atopology, ageom) );
-- Get layer information
BEGIN
SELECT *, CASE
WHEN feature_type = 1 THEN 'puntal'
WHEN feature_type = 2 THEN 'lineal'
WHEN feature_type = 3 THEN 'areal'
WHEN feature_type = 4 THEN 'mixed'
ELSE 'unexpected_'||feature_type
END as typename
FROM topology.layer l
INTO STRICT layer_info
WHERE l.layer_id = alayer
AND l.topology_id = topology_info.id;
EXCEPTION
RAISE EXCEPTION 'No layer with id "%" in topology "%"',
alayer, atopology;
END;
-- Can't convert to a hierarchical topogeometry
IF layer_info.level > 0 THEN
RAISE EXCEPTION 'Layer "%" of topology "%" is hierarchical, cannot
convert to it.',
alayer, atopology;
END IF;
-- Check type compatibility and create empty TopoGeometry
-- 1:puntal, 2:lineal, 3:areal, 4:collection
typ = geometrytype(ageom);
IF typ = 'GEOMETRYCOLLECTION' THEN
-- A collection can only go collection layer
IF layer_info.feature_type != 4 THEN
RAISE EXCEPTION
'Layer "%" of topology "%" is %, cannot hold a collection feature.',
layer_info.layer_id, topology_info.name, layer_info.typename;
END IF;
tg := topology.CreateTopoGeom(atopology, 4, alayer);
ELSIF typ = 'POINT' OR typ = 'MULTIPOINT' THEN -- puntal
-- A point can go in puntal or collection layer
IF layer_info.feature_type != 4 and layer_info.feature_type != 1 THEN
RAISE EXCEPTION
'Layer "%" of topology "%" is %, cannot hold a puntal feature.',
END IF;
tg := topology.CreateTopoGeom(atopology, 1, alayer);
ELSIF typ = 'LINESTRING' or typ = 'MULTILINESTRING' THEN -- lineal
-- A line can go in lineal or collection layer
IF layer_info.feature_type != 4 and layer_info.feature_type != 2 THEN
RAISE EXCEPTION
'Layer "%" of topology "%" is %, cannot hold a lineal feature.',
END IF;
tg := topology.CreateTopoGeom(atopology, 2, alayer);
ELSIF typ = 'POLYGON' OR typ = 'MULTIPOLYGON' THEN -- areal
-- An area can go in areal or collection layer
IF layer_info.feature_type != 4 and layer_info.feature_type != 3 THEN
RAISE EXCEPTION
'Layer "%" of topology "%" is %, cannot hold an areal feature.',
END IF;
tg := topology.CreateTopoGeom(atopology, 3, alayer);
ELSE
-- Should never happen
RAISE EXCEPTION
'Unsupported feature type %', typ;
END IF;
-- Now that we have a topogeometry, we loop over distinct components
-- and add them to the definition of it. We add them as soon
-- as possible so that each element can further edit the
-- definition by splitting
--modified to catch errors:
BEGIN
FOR rec IN SELECT DISTINCT id(tg), alayer as lyr,-- geom,
CASE WHEN ST_Dimension(geom) = 0 THEN 1
WHEN ST_Dimension(geom) = 1 THEN 2
WHEN ST_Dimension(geom) = 2 THEN 3
END as type,
topology.topogeo_addPoint(atopology, geom, tolerance)
topology.topogeo_addLineString(atopology, geom, tolerance)
topology.topogeo_addPolygon(atopology, geom, tolerance)
END as primitive
FROM (SELECT (ST_Dump(ageom)).geom) as f
WHERE NOT ST_IsEmpty(geom)
LOOP
--raise notice 'coucou, tg : %, geom %',rec.id, ST_AsText(rec.geom);
-- TODO: consider use a single INSERT statement for the whole thing
sql := 'INSERT INTO ' || quote_ident(atopology)
|| '.relation(topogeo_id, layer_id, element_type, element_id)
VALUES ('
|| rec.id || ',' || rec.lyr || ',' || rec.type
|| ',' || rec.primitive || ')';
EXECUTE sql;
END LOOP;
RETURN tg;
EXCEPTION
WHEN SQLSTATE 'P0001' THEN
RAISE NOTICE 'this geometry can''t be converted to topogeom : %
doing nothing',ageom;
RETURN NULL;
END;
END
$BODY$
LANGUAGE plpgsql VOLATILE STRICT
COST 100;
ALTER FUNCTION public.rc_totopogeomwithouterrors(geometry, character
OWNER TO postgres;
2014/1/15 Rémi Cura <remi.cura at gmail.com>
> Last chance :
> this function is a a sloghtly modified topogeom constructor that won't
> stop when habving an error.
> This way you can import everything that works, and then deal with the
> unworking ...
> 2014/1/15 Sandro Santilli <strk at keybit.net>
>> On Tue, Jan 14, 2014 at 04:10:45PM +0100, Ludovic Granjon wrote:
>> > UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
>> > ERREUR: Spatial exception - geometry intersects edge 262
>> > Have you a solution for that ?
>> Do the update in chunks. That way you'll import what can be and isolate
>> the offending record (if still offending) and then fight with that one
>> individually.
>> These kind of error sometime happen when the tolerance you specify
>> is bigger than the smallest distance between any two vertices in
>> your input dataset. An ST_SnapToGrid with given tolerance might also
>> give you better results, but the chunked loading is always the best
>> way to do topology building.
>> --strk;
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/ccd039dd/attachment.html>
