[postgis-users] postgis topology
Ludovic Granjon
ludovic.granjon at u-bourgogne.fr
Wed Jan 15 05:35:10 PST 2014
Thanks all, so
if I try like Sandro said :
UPDATE ec SET geom = ST_SnapToGrid(geom, 1);
UPDATE ec SET topo_geom = toTopoGeom(geom, 'ec_topo', 1, 1.0);
I have this error :
SQL/MM Spatial exception - curve not simple
If i increase tolerance parameter, I have :
ERREUR: SQL/MM Spatial exception - point not on edge
With Rémi's solution :
UPDATE ec SET topo_geom = rc_totopogeomwithouterrors(geom, 'ec_topo', 1,
1.0);
It works with a lot (76) of NOTICE: this geometry can't be converted to
topogeom :
but other geometry worked
so it's better
Now, I have to know why some geometry doesn't work
Maybe I have to explain more what I'm trying to do
My data overlap and there are not clean. Sometimes polygon should have
jointly vertex but it's not the case. (I join a image)
I want to snap when the distance is smaller than tolerance and intersect
polygon when they overlap.
Do you think that use topology is the best way to do that ?
Thanks a lot
regards
Ludovic
Le 15/01/2014 13:49, Rémi Cura a écrit :
> -- Function: public.rc_totopogeomwithouterrors(geometry, character
> varying, integer, double precision)
> -- DROP FUNCTION public.rc_totopogeomwithouterrors(geometry, character
> varying, integer, double precision);
> CREATE OR REPLACE FUNCTION public.rc_totopogeomwithouterrors(ageom
> geometry, atopology character varying, alayer integer, atolerance
> double precision DEFAULT 0)
> RETURNS topogeometry AS
> $BODY$
> DECLARE
> layer_info RECORD;
> topology_info RECORD;
> rec RECORD;
> tg topology.TopoGeometry;
> elems topology.TopoElementArray = '{{0,0}}';
> sql TEXT;
> typ TEXT;
> tolerance FLOAT8;
> BEGIN
> raise notice 'ageom : %',ST_AsText(ageom);
> -- Get topology information
> BEGIN
> SELECT *
> FROM topology.topology
> INTO STRICT topology_info WHERE name = atopology;
> EXCEPTION
> WHEN NO_DATA_FOUND THEN
> RAISE EXCEPTION 'No topology with name "%" in topology.topology',
> atopology;
> END;
> -- Get tolerance, if 0 was given
> tolerance := COALESCE( NULLIF(atolerance, 0),
> topology._st_mintolerance(atopology, ageom) );
> -- Get layer information
> BEGIN
> SELECT *, CASE
> WHEN feature_type = 1 THEN 'puntal'
> WHEN feature_type = 2 THEN 'lineal'
> WHEN feature_type = 3 THEN 'areal'
> WHEN feature_type = 4 THEN 'mixed'
> ELSE 'unexpected_'||feature_type
> END as typename
> FROM topology.layer l
> INTO STRICT layer_info
> WHERE l.layer_id = alayer
> AND l.topology_id = topology_info.id <http://topology_info.id>;
> EXCEPTION
> RAISE EXCEPTION 'No layer with id "%" in topology "%"',
> alayer, atopology;
> END;
> -- Can't convert to a hierarchical topogeometry
> IF layer_info.level > 0 THEN
> RAISE EXCEPTION 'Layer "%" of topology "%" is hierarchical,
> cannot convert to it.',
> alayer, atopology;
> END IF;
> -- Check type compatibility and create empty TopoGeometry
> -- 1:puntal, 2:lineal, 3:areal, 4:collection
> typ = geometrytype(ageom);
> IF typ = 'GEOMETRYCOLLECTION' THEN
> -- A collection can only go collection layer
> IF layer_info.feature_type != 4 THEN
> RAISE EXCEPTION
> 'Layer "%" of topology "%" is %, cannot hold a collection
> feature.',
> layer_info.layer_id, topology_info.name
> <http://topology_info.name>, layer_info.typename;
> END IF;
> tg := topology.CreateTopoGeom(atopology, 4, alayer);
> ELSIF typ = 'POINT' OR typ = 'MULTIPOINT' THEN -- puntal
> -- A point can go in puntal or collection layer
> IF layer_info.feature_type != 4 and layer_info.feature_type != 1 THEN
> RAISE EXCEPTION
> 'Layer "%" of topology "%" is %, cannot hold a puntal feature.',
> END IF;
> tg := topology.CreateTopoGeom(atopology, 1, alayer);
> ELSIF typ = 'LINESTRING' or typ = 'MULTILINESTRING' THEN -- lineal
> -- A line can go in lineal or collection layer
> IF layer_info.feature_type != 4 and layer_info.feature_type != 2 THEN
> RAISE EXCEPTION
> 'Layer "%" of topology "%" is %, cannot hold a lineal feature.',
> END IF;
> tg := topology.CreateTopoGeom(atopology, 2, alayer);
> ELSIF typ = 'POLYGON' OR typ = 'MULTIPOLYGON' THEN -- areal
> -- An area can go in areal or collection layer
> IF layer_info.feature_type != 4 and layer_info.feature_type != 3 THEN
> RAISE EXCEPTION
> 'Layer "%" of topology "%" is %, cannot hold an areal feature.',
> END IF;
> tg := topology.CreateTopoGeom(atopology, 3, alayer);
> ELSE
> -- Should never happen
> RAISE EXCEPTION
> 'Unsupported feature type %', typ;
> END IF;
> -- Now that we have a topogeometry, we loop over distinct components
> -- and add them to the definition of it. We add them as soon
> -- as possible so that each element can further edit the
> -- definition by splitting
> --modified to catch errors:
> BEGIN
> FOR rec IN SELECT DISTINCT id(tg), alayer as lyr,-- geom,
> CASE WHEN ST_Dimension(geom) = 0 THEN 1
> WHEN ST_Dimension(geom) = 1 THEN 2
> WHEN ST_Dimension(geom) = 2 THEN 3
> END as type,
> topology.topogeo_addPoint(atopology, geom, tolerance)
> topology.topogeo_addLineString(atopology, geom, tolerance)
> topology.topogeo_addPolygon(atopology, geom, tolerance)
> END as primitive
> FROM (SELECT (ST_Dump(ageom)).geom) as f
> WHERE NOT ST_IsEmpty(geom)
> LOOP
> --raise notice 'coucou, tg : %, geom %',rec.id <http://rec.id>,
> ST_AsText(rec.geom);
> -- TODO: consider use a single INSERT statement for the whole thing
> sql := 'INSERT INTO ' || quote_ident(atopology)
> || '.relation(topogeo_id, layer_id, element_type, element_id)
> VALUES ('
> || rec.id <http://rec.id> || ',' || rec.lyr || ',' || rec.type
> || ',' || rec.primitive || ')';
> EXECUTE sql;
> END LOOP;
> RETURN tg;
> EXCEPTION
> WHEN SQLSTATE 'P0001' THEN
> RAISE NOTICE 'this geometry can''t be converted to topogeom : %
> doing nothing',ageom;
> RETURN NULL;
> END;
> END
> $BODY$
> LANGUAGE plpgsql VOLATILE STRICT
> COST 100;
> ALTER FUNCTION public.rc_totopogeomwithouterrors(geometry, character
> OWNER TO postgres;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/dc017964/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/dc017964/attachment.vcf>
