[postgis-users] postgis topology
Ludovic Granjon
ludovic.granjon at u-bourgogne.fr
Wed Jan 15 05:36:38 PST 2014
The image
Le 15/01/2014 14:35, Ludovic Granjon a écrit :
> Thanks all, so
> if I try like Sandro said :
> UPDATE ec SET geom = ST_SnapToGrid(geom, 1);
> UPDATE ec SET topo_geom = toTopoGeom(geom, 'ec_topo', 1, 1.0);
> I have this error :
> SQL/MM Spatial exception - curve not simple
> If i increase tolerance parameter, I have :
> ERREUR: SQL/MM Spatial exception - point not on edge
> With Rémi's solution :
> UPDATE ec SET topo_geom = rc_totopogeomwithouterrors(geom, 'ec_topo',
> 1, 1.0);
> It works with a lot (76) of NOTICE: this geometry can't be converted
> to topogeom :
> but other geometry worked
> so it's better
> Now, I have to know why some geometry doesn't work
> Maybe I have to explain more what I'm trying to do
> My data overlap and there are not clean. Sometimes polygon should have
> jointly vertex but it's not the case. (I join a image)
> I want to snap when the distance is smaller than tolerance and
> intersect polygon when they overlap.
> Do you think that use topology is the best way to do that ?
> Thanks a lot
> regards
> Ludovic
> Le 15/01/2014 13:49, Rémi Cura a écrit :
>> -- Function: public.rc_totopogeomwithouterrors(geometry, character
>> varying, integer, double precision)
>> -- DROP FUNCTION public.rc_totopogeomwithouterrors(geometry,
>> character varying, integer, double precision);
>> CREATE OR REPLACE FUNCTION public.rc_totopogeomwithouterrors(ageom
>> geometry, atopology character varying, alayer integer, atolerance
>> double precision DEFAULT 0)
>> RETURNS topogeometry AS
>> $BODY$
>> DECLARE
>> layer_info RECORD;
>> topology_info RECORD;
>> rec RECORD;
>> tg topology.TopoGeometry;
>> elems topology.TopoElementArray = '{{0,0}}';
>> sql TEXT;
>> typ TEXT;
>> tolerance FLOAT8;
>> BEGIN
>> raise notice 'ageom : %',ST_AsText(ageom);
>> -- Get topology information
>> BEGIN
>> SELECT *
>> FROM topology.topology
>> INTO STRICT topology_info WHERE name = atopology;
>> EXCEPTION
>> WHEN NO_DATA_FOUND THEN
>> RAISE EXCEPTION 'No topology with name "%" in topology.topology',
>> atopology;
>> END;
>> -- Get tolerance, if 0 was given
>> tolerance := COALESCE( NULLIF(atolerance, 0),
>> topology._st_mintolerance(atopology, ageom) );
>> -- Get layer information
>> BEGIN
>> SELECT *, CASE
>> WHEN feature_type = 1 THEN 'puntal'
>> WHEN feature_type = 2 THEN 'lineal'
>> WHEN feature_type = 3 THEN 'areal'
>> WHEN feature_type = 4 THEN 'mixed'
>> ELSE 'unexpected_'||feature_type
>> END as typename
>> FROM topology.layer l
>> INTO STRICT layer_info
>> WHERE l.layer_id = alayer
>> AND l.topology_id = topology_info.id <http://topology_info.id>;
>> EXCEPTION
>> RAISE EXCEPTION 'No layer with id "%" in topology "%"',
>> alayer, atopology;
>> END;
>> -- Can't convert to a hierarchical topogeometry
>> IF layer_info.level > 0 THEN
>> RAISE EXCEPTION 'Layer "%" of topology "%" is hierarchical,
>> cannot convert to it.',
>> alayer, atopology;
>> END IF;
>> -- Check type compatibility and create empty TopoGeometry
>> -- 1:puntal, 2:lineal, 3:areal, 4:collection
>> typ = geometrytype(ageom);
>> IF typ = 'GEOMETRYCOLLECTION' THEN
>> -- A collection can only go collection layer
>> IF layer_info.feature_type != 4 THEN
>> RAISE EXCEPTION
>> 'Layer "%" of topology "%" is %, cannot hold a collection
>> feature.',
>> layer_info.layer_id, topology_info.name
>> <http://topology_info.name>, layer_info.typename;
>> END IF;
>> tg := topology.CreateTopoGeom(atopology, 4, alayer);
>> ELSIF typ = 'POINT' OR typ = 'MULTIPOINT' THEN -- puntal
>> -- A point can go in puntal or collection layer
>> IF layer_info.feature_type != 4 and layer_info.feature_type != 1 THEN
>> RAISE EXCEPTION
>> 'Layer "%" of topology "%" is %, cannot hold a puntal feature.',
>> END IF;
>> tg := topology.CreateTopoGeom(atopology, 1, alayer);
>> ELSIF typ = 'LINESTRING' or typ = 'MULTILINESTRING' THEN -- lineal
>> -- A line can go in lineal or collection layer
>> IF layer_info.feature_type != 4 and layer_info.feature_type != 2 THEN
>> RAISE EXCEPTION
>> 'Layer "%" of topology "%" is %, cannot hold a lineal feature.',
>> END IF;
>> tg := topology.CreateTopoGeom(atopology, 2, alayer);
>> ELSIF typ = 'POLYGON' OR typ = 'MULTIPOLYGON' THEN -- areal
>> -- An area can go in areal or collection layer
>> IF layer_info.feature_type != 4 and layer_info.feature_type != 3 THEN
>> RAISE EXCEPTION
>> 'Layer "%" of topology "%" is %, cannot hold an areal feature.',
>> END IF;
>> tg := topology.CreateTopoGeom(atopology, 3, alayer);
>> ELSE
>> -- Should never happen
>> RAISE EXCEPTION
>> 'Unsupported feature type %', typ;
>> END IF;
>> -- Now that we have a topogeometry, we loop over distinct components
>> -- and add them to the definition of it. We add them as soon
>> -- as possible so that each element can further edit the
>> -- definition by splitting
>> --modified to catch errors:
>> BEGIN
>> FOR rec IN SELECT DISTINCT id(tg), alayer as lyr,-- geom,
>> CASE WHEN ST_Dimension(geom) = 0 THEN 1
>> WHEN ST_Dimension(geom) = 1 THEN 2
>> WHEN ST_Dimension(geom) = 2 THEN 3
>> END as type,
>> topology.topogeo_addPoint(atopology, geom, tolerance)
>> topology.topogeo_addLineString(atopology, geom, tolerance)
>> topology.topogeo_addPolygon(atopology, geom, tolerance)
>> END as primitive
>> FROM (SELECT (ST_Dump(ageom)).geom) as f
>> WHERE NOT ST_IsEmpty(geom)
>> LOOP
>> --raise notice 'coucou, tg : %, geom %',rec.id <http://rec.id>,
>> ST_AsText(rec.geom);
>> -- TODO: consider use a single INSERT statement for the whole thing
>> sql := 'INSERT INTO ' || quote_ident(atopology)
>> || '.relation(topogeo_id, layer_id, element_type, element_id)
>> VALUES ('
>> || rec.id <http://rec.id> || ',' || rec.lyr || ',' || rec.type
>> || ',' || rec.primitive || ')';
>> EXECUTE sql;
>> END LOOP;
>> RETURN tg;
>> EXCEPTION
>> WHEN SQLSTATE 'P0001' THEN
>> RAISE NOTICE 'this geometry can''t be converted to topogeom : %
>> doing nothing',ageom;
>> RETURN NULL;
>> END;
>> END
>> $BODY$
>> LANGUAGE plpgsql VOLATILE STRICT
>> COST 100;
>> ALTER FUNCTION public.rc_totopogeomwithouterrors(geometry, character
>> OWNER TO postgres;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/e1dee683/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/e1dee683/attachment.png>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/e1dee683/attachment.vcf>
