[postgis-users] PostGIS 2.0.4 on MacOS X 10.7.5 Library Not Loaded: libintl.8.dylib
David Walrath dcw8 at psu.edu
Wed Jan 22 12:48:59 PST 2014
Thanks for the reply. You are correct - the file is missing from the lib directory. I did email EDB and suggested this to them but I don't think I was dealing with the correct person as their primary recommendation was to buy a prod or dev support contract and they would see what they could do.  I wound up scrapping the EDB install and going with the Postgres/postgis install from KyngChaos... got everything installed and working in about 5mins.
David
On Jan 22, 2014, at 3:11 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Yes, probably the installer is missing the file (go to the location of
> shp2pgsql and ls ../lib/ and see if libintl shows up there, probably
> it doesn't. So inform EDB that their packager is forgetting to include
> a file. They probably don't test the commandline components as much as
> the GUI ones.
> P.
> On Tue, Jan 21, 2014 at 5:01 AM, David Walrath <dcw8 at psu.edu> wrote:
>> Hello.  I downloaded and installed PostgreSQL 9.2.6-2 and PostGIS 2.0.4-1
>> from EnterpriseDB.com.   I had no errors during the installation of postgres
>> and postgis and I was able to create a spatially enabled database within
>> postgres using the pgAdmin III client.  However, issuing the raster2pgsql
>> command produces an error that reads:
>> dylid:  Library not loaded: @loader_path/../lib/libintl.8.dylib
>>    Referenced from: /Library/PostgreSQL/9.2/bin/raster2pgsql
>>    Reason: image not found
>> Trace/BPT trap: 5
>> The shp2pgsql command produces the same error.  I used the locate command to
>> find the referenced libintl.8.dylib file and it was not found on my
>> computer.
>> Is the problem that the installer package is missing this file?  If so, is
>> there a workaround?
>> Thank you.
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
