[postgis-users] PostGIS 2.0.4 on MacOS X 10.7.5 Library Not Loaded: libintl.8.dylib
Paul Ramsey pramsey at cleverelephant.ca
Wed Jan 22 12:11:53 PST 2014
Yes, probably the installer is missing the file (go to the location of
shp2pgsql and ls ../lib/ and see if libintl shows up there, probably
it doesn't. So inform EDB that their packager is forgetting to include
a file. They probably don't test the commandline components as much as
the GUI ones.
P.
On Tue, Jan 21, 2014 at 5:01 AM, David Walrath <dcw8 at psu.edu> wrote:
> Hello.  I downloaded and installed PostgreSQL 9.2.6-2 and PostGIS 2.0.4-1
> from EnterpriseDB.com.   I had no errors during the installation of postgres
> and postgis and I was able to create a spatially enabled database within
> postgres using the pgAdmin III client.  However, issuing the raster2pgsql
> command produces an error that reads:
> dylid:  Library not loaded: @loader_path/../lib/libintl.8.dylib
>     Referenced from: /Library/PostgreSQL/9.2/bin/raster2pgsql
>     Reason: image not found
> Trace/BPT trap: 5
> The shp2pgsql command produces the same error.  I used the locate command to
> find the referenced libintl.8.dylib file and it was not found on my
> computer.
> Is the problem that the installer package is missing this file?  If so, is
> there a workaround?
> Thank you.
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
