[postgis-users] Migration from 1.3.1 to 2.0
Bborie Park dustymugs at gmail.com
Sat Jan 25 07:55:54 PST 2014
The only thing that should be different is that the geometry datatype will
not be constrained (geometry vs geometry(POINT, 4326)). It'll probably be
constrained using the traditional column constraints.
Otherwise, I don't see any problems. Just make sure to have a full backup
of the DB.
-bborie
On Fri, Jan 24, 2014 at 8:53 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi,
> I need to migrate a database
> from:
> PostgreSQL 8.2.14
> POSTGIS="1.3.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
> USE_STATS
> to:
> Postgresql 9.2.x
> POSTGIS 2.0.x
> Will using pg_dump to dump just the tables I need in plain text format,
> then load them into a new database with the postgis extension work? or will
> I run into problems doing this?
> Thanks,
>   -Steve W
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140125/16b75bd5/attachment.html>
