[postgis-users] Removing tiny polygons
Astrid Bjørnerød
aeb at skogoglandskap.no
Mon Jan 27 22:18:56 PST 2014
Is there anyone you have written some sql-code for removing the small polygons onto one of the neighbor-polygons ?
Any stabil functions for this task?
Astrid
-----Opprinnelig melding-----
Fra: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] På vegne av Tom McCallum
Sendt: 27. januar 2014 20:48
Til: morten at sickel.net; PostGIS Users Discussion
Emne: Re: [postgis-users] Removing tiny polygons
Thanks Morten. I wanted the first case, so that helps.
On Mon, 27 Jan 2014 19:15:18 -0000, Morten Sickel <morten at sickel.net>
wrote:
> It depends on what you mean with "remove" - do you want to just have
> the large polygons without the area that is covered by the small ones
> or do you want to add the area of the small polygons onto one or more
> of the larges? (e.g. how one typically wants to handle shiver
> polygons)
> In the first case it is as easy as a query like
> select the_geom where ST_area(the_geom) > ...
> Morten
> Tom McCallum skrev:
>> Hi all,
>> If I have a polygon geometry field which seems to be made up of a
>> large number of tiny polygons and some larger ones, what is the best
>> way to remove polygons below a certain size? Would I need to
>> preprocess this and save in a new table/record or can I dynamically
>> do it?
>> Thanks
>> Tom
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
