[postgis-users] Removing tiny polygons
Tom McCallum
termcc at googlemail.com
Mon Jan 27 11:48:25 PST 2014
Thanks Morten. I wanted the first case, so that helps.
On Mon, 27 Jan 2014 19:15:18 -0000, Morten Sickel <morten at sickel.net>
wrote:
> It depends on what you mean with "remove" - do you want to just have the
> large polygons without the area that is covered by the small ones or do
> you want to add the area of the small polygons onto one or more of the
> larges? (e.g. how one typically wants to handle shiver polygons)
> In the first case it is as easy as a query like
> select the_geom where ST_area(the_geom) > ...
> Morten
> Tom McCallum skrev:
>> Hi all,
>> If I have a polygon geometry field which seems to be made up of a large
>> number of tiny polygons and some larger ones, what is the best way to
>> remove polygons below a certain size? Would I need to preprocess this
>> and
>> save in a new table/record or can I dynamically do it?
>> Thanks
>> Tom
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
