[postgis-users] ST_SummaryStatsAgg not working with PostgreSQL 9.3 + PostGIS 2.1.1
Hailey Eckstrand
haileyeckstrand at gmail.com
Fri Jan 31 10:26:42 PST 2014
Thank you Bborie, it looks to be working successfully now.
On Fri, Jan 31, 2014 at 10:17 AM, Bborie Park <dustymugs at gmail.com> wrote:
> Put the following at the top of your file...
> CREATE TYPE summarystats AS (
> count bigint,
> sum double precision,
> mean double precision,
> stddev double precision,
> min double precision,
> max double precision
> -bborie
> On Fri, Jan 31, 2014 at 9:41 AM, Hailey Eckstrand <
> haileyeckstrand at gmail.com> wrote:
>> It was from a post on the PostGIS User Discussion that I made last year
>> from Pierre Racine:
>> http://lists.osgeo.org/pipermail/postgis-users/2013-August/037514.html
>> Is it possible to get this functionality working with PostGIS 2.1?
>> Thanks,
>> Hailey
>> On Fri, Jan 31, 2014 at 9:33 AM, Bborie Park <dustymugs at gmail.com> wrote:
>>> PostGIS 2.1 does not have the data type summarystats. Where did you get
>>> this function?
>>> PostGIS 2.2 (in development now) does have that data type though for a
>>> built in ST_SummaryStatsAgg function.
>>> -bborie
>>> On Jan 31, 2014 9:23 AM, "Hailey Eckstrand" <haileyeckstrand at gmail.com>
>>> wrote:
>>>> Hi bborie,
>>>> After changing it from 'SQL' to 'sql' this is the error:
>>>> $psql mydb -f ST_SummaryStatsAgg.sql
>>>> psql:ST_SummaryStatsAgg.sql:50: ERROR: type summarystats does not exist
>>>> psql:ST_SummaryStatsAgg.sql:56: ERROR: type summarystats does not exist
>>>> psql:ST_SummaryStatsAgg.sql:77: ERROR: type summarystats does not exist
>>>> psql:ST_SummaryStatsAgg.sql:86: ERROR: type "summarystats" does not
>>>> exist
>>>> psql:ST_SummaryStatsAgg.sql:92: ERROR: type "summarystats" does not
>>>> exist
>>>> CREATE FUNCTION
>>>> psql:ST_SummaryStatsAgg.sql:121: ERROR: function
>>>> st_summarystatsagg(raster) does not exist
>>>> LINE 8: FROM (SELECT ST_SummaryStatsAgg(rast) as ss, id
>>>> HINT: No function matches the given name and argument types. You might
>>>> need to add explicit type casts.
>>>> Does PostgreSQL 9.3 still have the data type summarystats? Also, the
>>>> function that ST_SummaryStatsAgg.sql relies on, ST_SummaryStats.sql, has it
>>>> remained the same?
>>>> Thanks,
>>>> Hailey
>>>> On Fri, Jan 31, 2014 at 6:53 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>> Can you change line 56 of that code from ...
>>>>> $$ LANGUAGE 'SQL';
>>>>> to
>>>>> $$ LANGUAGE 'sql';
>>>>> I believe PostgreSQL 9.3 (maybe 9.2) became case-sensitive with
>>>>> regards to the language.
>>>>> -bborie
>>>>> On Thu, Jan 30, 2014 at 4:41 PM, Hailey Eckstrand <
>>>>>> Hello,
>>>>>> I've got a new sandbox (Ubuntu 12.04) with a fresh install on
>>>>>> PostgreSQL 9.3 and the following for PostGIS version:
>>>>>> postgis_full_version
>>>>>> POSTGIS="2.1.1 r12113" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel.
>>>>>> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.8"
>>>>>> LIBJSON="UNKNOWN" TOPOLOGY RASTER
>>>>>> (1 row)
>>>>>> I just ran into a problem where I tried to run ST_SummaryStatsAgg on
>>>>>> a raster for a polygon and ended up with an error. I thought it was b/c I
>>>>>> did not have the function loaded, so when I tried to load the
>>>>>> function ST_SummaryStatsAgg.sql, I got the following errors:
>>>>>> exist
>>>>>> psql:ST_SummaryStatsAgg.sql:56: ERROR: language "SQL" does not exist
>>>>>> exist
>>>>>> exist
>>>>>> exist
>>>>>> CREATE FUNCTION
>>>>>> might need to add explicit type casts.
>>>>>> Here is the current ST_SummaryStatsAgg that I am trying to load:
>>>>>> http://hastebin.com/lujenosaro.pas
>>>>>> Thanks!
>>>>>> Hailey
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140131/2c1a1016/attachment.html>
