[postgis-users] Finding records withing XX distance from a geometry in the same table
Rémi Cura
remi.cura at gmail.com
Thu Jul 10 08:58:40 PDT 2014
Hey,
I'm glad you found out.
I never tried but you could probably try to index on the result of the cast
CREATE INDEX ON ... USING GIST ((CAST geom AS GEOGRAPHY))
However if your distance are not that big (compaired to earth curve), stick
to geometry.
If your distances are big, go geography.
You could also simply do it in 2 steps, a first step with geometry and
maybe 2 times the distance to be sure on all the table, a second step more
precise with geography on only the result of the previous filter.
Cheers,
Rémi-C
2014-07-10 17:47 GMT+02:00 Alexander W. Rolek <a.rolek at gmail.com>:
> Remi -
> Thanks again for the quick response. I dug into this a bit more last
> night, and apparently the issue was the distance I was using with the
> ST_DWithin call. When I had a projection under 2230, the unit of measure
> was feet. With 4326 it appears to be degrees. I kept the distance of 100 on
> both tests, so the 2230 project returned quick, but a distance of 100 on a
> 4326 projection is very large so it was returning my whole table. When I
> changed the distance to something small (0.0009) my query is now fast. ;-)
> My next challenge will be figuring out the best way to convert between
> degrees & meters. I understand the geography type is better for queries
> like this, but I'm already using the geometry type for other queries. Is it
> common to have both geometry and geography for a record in a table? I know
> I can cast using ::geography but the queries are dramatically slower.
> Alex
> On Thu, Jul 10, 2014 at 1:11 AM, Rémi Cura <remi.cura at gmail.com> wrote:
>> Hey,
>> If I take into account your last mail,
>> you probably have forget to transform your data.
>> If you have a table in srid 4326
>> , you can't use a transform in your querry if you want it to uses indexes.
>> OR you have to buil and index like this :
>> CREATE INDEX ON sdgis.parcels4326 USING GIST (ST_Transform(geom, 4326));
>> So can you confirm thatl your geom have the correct srid in the correct
>> table?
>> SELECT DISTINCT ST_SRID(geom)
>> FROM sdgis.parcels ;
>> and
>> FROM sdgis.parcels4326 ;
>> You uses pgadmin , so instead of running your querry
>> , run it with "explain analyse" (Select the text of your querry, then
>> press shift+F7).
>> You should see a graphic explaining what it happening. You should look
>> for sequential scans.
>> You can also try the same querry without CTE :
>> SELECT p.*
>> FROM (
>> SELECT geom
>> FROM sdgis.parcels4326 AS parcels
>> WHERE apn = '3500600300
>> ) AS mip
>> INNER JOIN sdgis.parcels4326 AS p ON
>> (ST_DWITHIN(mip.geom,p.geom,100)=TRUE);
>> Of course vacuum analyze both table before running the querry.
>> It would be difficult to help you more without detailed information
>> (tables declarations, querry used, result of explain analyse), because
>> slowness can come from several reasons .
>> Here is a link of requirements for people having slow querry on postgres
>> mailing list (https://wiki.postgresql.org/wiki/Slow_Query_Questions).
>> I'm not guru so I couldn't use all this informations but that give you an
>> idea of how many reasons of slow query they can be
>> Cheers,
>> Rémi-C
>> I tried the query that Remi suggested (thank you!) and it works and
>> doesn't work. I have the exact same table in two different projections
>> (2230, 4326). When I run the ST_Dwithin query against the 2230 table, I get
>> results in under 100 ms. When I run the same query against the 4326
>> projection it still takes around 270 seconds! I have confirmed that I have
>> the gist index on the 4326 table. Any ideas why the 4326 projection would
>> be dramatically slower?
>> 2014-07-09 18:38 GMT+02:00 Alexander W. Rolek <a.rolek at gmail.com>:
>> Remi -
>>> Thanks for the quick response. Sorry to respond to you directly, but my
>>> message settings are set on digest so I can't respond to the thread yet.
>>> I went through your steps, and have built out my query, but it's still
>>> taking around 270 seconds to run the query, and it's returning ever record
>>> in my table. Here's my query:
>>> WITH my_input_polygon AS (
>>> SELECT geom
>>> WHERE apn = '3500600300'
>>> SELECT p.*
>>> FROM my_input_polygon AS mip
>>> I also have indexes on the apn and the geom columns (see attached screen
>>> shots)
>>> Any ideas what I'm missing here?
>>> Thanks again for the help
>>> Alexander W. Rolek
> Alexander W. Rolek
> 303-829-9989
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140710/8b031d3f/attachment.html>
