[postgis-users] PostGIS non functional on Ubuntu 14.04
Rémi Cura remi.cura at gmail.com
Fri Jul 25 01:36:47 PDT 2014
Hey,
probably not the answer you are looking for,
but:
#get postgis
git clone https://github.com/postgis/postgis/ postgis
#go in folder
cd postgis
#build & install postgis
sudo ./configure
sudo make
sudo make install
#restart postgres
sudo pg_ctlcluster 9.3 main restart
Cheers,
Rémi-C
2014-07-25 10:03 GMT+02:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Dear all,
> I have the following packages installed on Ubuntu 14.04 (all fetched
> with apt from the repositories):
> . postgresql-9.3
> . postgresql-9.3-postgis-2.1
> . libgeos-3.4.2
> When I try to add the PostGIS extension to a database I get following
> message:
> $  psql pg_testing -c "create extension postgis"
> ERROR:  could not load library
> "/usr/lib/postgresql/9.3/lib/postgis-2.1.so":
> /usr/lib/liblwgeom-2.1.3.so: undefined symbol:
> GEOSDelaunayTriangulation
> I have posted full package details at GIS.SE:
> http://gis.stackexchange.com/questions/108308/postgis-non-functional-on-ubuntu-14-04
> Apparently, there is some mismatch between libgeos and postgis. But I
> have the exact same versions indicated in the compile guide at the
> Wiki:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
> Any advice on how to get PostGIS running is welcome. Thank you,
> Luís
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140725/1157376a/attachment.html>
