[postgis-users] PostGIS non functional on Ubuntu 14.04
Clifford Snow
clifford at snowandsnow.us
Fri Jul 25 08:35:39 PDT 2014
On Fri, Jul 25, 2014 at 1:03 AM, Luís de Sousa <luis.a.de.sousa at gmail.com>
wrote:
> I have the following packages installed on Ubuntu 14.04 (all fetched
> with apt from the repositories):
> . postgresql-9.3
> . postgresql-9.3-postgis-2.1
> . libgeos-3.4.2
> When I try to add the PostGIS extension to a database I get following
> message:
> $ psql pg_testing -c "create extension postgis"
> ERROR: could not load library
> "/usr/lib/postgresql/9.3/lib/postgis-2.1.so":
> /usr/lib/liblwgeom-2.1.3.so: undefined symbol:
> GEOSDelaunayTriangulation
> I have posted full package details at GIS.SE:
> http://gis.stackexchange.com/questions/108308/postgis-non-functional-on-ubuntu-14-04
> Apparently, there is some mismatch between libgeos and postgis. But I
> have the exact same versions indicated in the compile guide at the
> Wiki:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
> Any advice on how to get PostGIS running is welcome. Thank you,
Not sure if this is the same problem, but when I upgraded to 14.04, along
with a new version of postgis/postgresql, postgis failed. The warning were
different. With help I discovered that I had conflicting libraries
installed that were causing the problem.
If you have older versions of postgis installed, make sure to remove all
the old libraries starting with liblwgeom.
Clifford
@osm_seattle
osm_seattle.snowandsnow.us
OpenStreetMap: Maps with a human touch
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140725/28bc6435/attachment.html>
