[postgis-users] PostGIS non functional on Ubuntu 14.04
Luís de Sousa
luis.a.de.sousa at gmail.com
Mon Jul 28 08:10:22 PDT 2014
Hi Mike, thank you for tips.
In fact I have several "old" .so files installed:
$ locate libgeos_c.so
/usr/lib/libgeos_c.so
/usr/lib/libgeos_c.so.1
/usr/lib/libgeos_c.so.1.8.2
/usr/local/lib/libgeos_c.so
/usr/local/lib/libgeos_c.so.1
/usr/local/lib/libgeos_c.so.1.7.1
/usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so
/usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1
/usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1
/usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1T
/usr/share/gvSIG-desktop-2.0.0/gvSIG/extensiones/org.gvsig.raster.tilecache.app/install/files/native/libgeos_c.so.1
/usr/share/gvSIG-desktop-2.0.0/native/libgeos_c.so.1
The problem is that running dpkg only libgeos-3.4.2 shows up:
$ dpkg -l | grep libgeos
ii libgeos-3.4.2
3.4.2-4ubuntu1 amd64
Geometry engine for Geographic Information Systems - C++ Library
ii libgeos-c1
Geometry engine for Geographic Information Systems - C Library
ii libgeos-dev
Geometry engine for GIS - Development files
Meaning that these old .so must be removed manually. In my experience
this always leads to other problems down the road. Any hints on how to
safely remove these old files is welcome.
Another thing: why were these files left in the system, if the
corresponding package is no longer installed? Is this a problem with
the Ubuntu upgrade procedure? Or an issue with the package itself?
Thank you,
Luís
On 28 July 2014 13:19, Mike Toews <mwtoews at gmail.com> wrote:
> On 25 July 2014 20:03, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
>> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
> Whoa, someone edited those for "trusty", and are a bit off. I've
> rolled those back to 13.10, and assembled a virtual machine for more
> instructions. Look for more appropriate source build instructions at:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404src
> And really simple package installation instructions at:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404pkg
> While I'm unable to reproduce your error from Ubuntu packages, it
> looks like you are on the correct track on removing older libraries of
> lwgeom and geos_c. E.g., a clean install from packages should see
> this:
> -Mike
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
