[postgis-users] PostGIS non functional on Ubuntu 14.04
António M. Rodrigues
amcrgrodrigues at gmail.com
Mon Jul 28 08:26:06 PDT 2014
A while back I had a similar problem upgrading from 2.0 to 2.1
Going throught my notes I found this which might help:
sudo ln -s /usr/lib/postgresql/9.1/lib/postgis-2.1.so
/usr/lib/postgresql/9.1/lib/postgis-2.0
ldconfig
You're basically creating a symbolic link with the older library.
Hope it helps,
António
2014-07-28 16:10 GMT+01:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Hi Mike, thank you for tips.
> In fact I have several "old" .so files installed:
> $ locate libgeos_c.so
> /usr/lib/libgeos_c.so
> /usr/lib/libgeos_c.so.1
> /usr/lib/libgeos_c.so.1.8.2
> /usr/local/lib/libgeos_c.so
> /usr/local/lib/libgeos_c.so.1
> /usr/local/lib/libgeos_c.so.1.7.1
> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so
> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1
> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1
> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1T
> /usr/share/gvSIG-desktop-2.0.0/gvSIG/extensiones/org.gvsig.raster.tilecache.app/install/files/native/libgeos_c.so.1
> /usr/share/gvSIG-desktop-2.0.0/native/libgeos_c.so.1
> The problem is that running dpkg only libgeos-3.4.2 shows up:
> $ dpkg -l | grep libgeos
> ii libgeos-3.4.2
> 3.4.2-4ubuntu1 amd64
> Geometry engine for Geographic Information Systems - C++ Library
> ii libgeos-c1
> Geometry engine for Geographic Information Systems - C Library
> ii libgeos-dev
> Geometry engine for GIS - Development files
> Meaning that these old .so must be removed manually. In my experience
> this always leads to other problems down the road. Any hints on how to
> safely remove these old files is welcome.
> Another thing: why were these files left in the system, if the
> corresponding package is no longer installed? Is this a problem with
> the Ubuntu upgrade procedure? Or an issue with the package itself?
> Thank you,
> Luís
> On 28 July 2014 13:19, Mike Toews <mwtoews at gmail.com> wrote:
> > On 25 July 2014 20:03, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
> >> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
> > Whoa, someone edited those for "trusty", and are a bit off. I've
> > rolled those back to 13.10, and assembled a virtual machine for more
> > instructions. Look for more appropriate source build instructions at:
> > http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404src
> > And really simple package installation instructions at:
> > http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404pkg
> > While I'm unable to reproduce your error from Ubuntu packages, it
> > looks like you are on the correct track on removing older libraries of
> > lwgeom and geos_c. E.g., a clean install from packages should see
> > this:
> > -Mike
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140728/7e0e7efe/attachment.html>
