[postgis-users] PG 2.0 to add table with heterogeneous geometry in QGIS
Preuß, Sylvia
Sylvia.Preuss at obk.de
Thu Jul 31 04:46:41 PDT 2014
I tried with and without checking this option. I get an attribut-table but no geometry. It’s just like csv.
Sylvia
>From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Åsmund Tokheim
>Sent: Thursday, July 31, 2014 12:25 PM
>To: PostGIS Users Discussion
>Subject: Re: [postgis-users] PG 2.0 to add table with heterogeneous geometry in QGIS
>Hi
>When you create/edit a postgis-connection in qgis, there should be an checkbox named something like "Don't resolve type of unrestricted >columns". Your table will not be listed if this option is checked.
>Åsmund
>2014-07-31 11:29 GMT+02:00 Preuß, Sylvia <Sylvia.Preuss at obk.de<mailto:Sylvia.Preuss at obk.de>>:
>Hello list,
>I have heterogeneous geometry (Polygon and MultiPolygon ) in one single table.
>CREATE TABLE myschema.mytable
>( gid serial NOT NULL,
> the_geom geometry(geometry,25832),
>CONSTRAINT pkey_mytable PRIMARY KEY (gid)
>Unfortunately I can’t add this as a PostGIS –Layer in QGIS. The geometry is not found.
>Same behaviour with
>CREATE TABLE myschema. mytable
> the_geom geometry,
>CONSTRAINT pkey_ mytable PRIMARY KEY (gid)
>I can’t do it like this:
> the_geom geometry(Polygon OR MultiPolygon,25832),
>PostGIS version:
>2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
>Postgres version:
>PostgreSQL 9.2.8, compiled by Visual C++ build 1600, 64-bit
>QGIS 2.4.0
>Sylvia
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der dienstlichen Kommunikation.
Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.
Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger gelten abweichende Regelungen.
Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht.
Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird, die infolge etwaiger Software-Viren entstehen könnten.
Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140731/4cc2a92e/attachment.html>
