[postgis-users] Querying Multiple Rasters
Jayson Gallardo
jaysontrades at gmail.com
Mon Jun 2 13:12:38 PDT 2014
I hate to bump this thread again, but I left this issue to work on more
pertinent things, and I finally am able to come back to this. I tried
playing around with ST_Buffer, and clipping the resulting bigger raster,
but I still get one or more borders consisting of NODATA values. This is
what I have right now:
sql_text_asciigrid = 'SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
ST_Transform(ST_Buffer(ST_GeomFromText(\'%s\',%i),1),%i)),\'%s\',ARRAY[\'FORCE_CELLSIZE=YES\'])
FROM "%s" WHERE ST_Intersects(rast,
ST_Transform(ST_Buffer(ST_GeomFromText(\'%s\',%i),10),%i))' % (wkt,
map_srs, table_srs, raster_type, table_name, wkt, map_srs, table_srs)
Is this something with ST_CLIP and geometries?
Thanks in advance,
Jayson
On Wed, Jan 8, 2014 at 9:39 AM, Jayson Gallardo <jaysontrades at gmail.com>
wrote:
> Sorry to bring up an old thread, but the following question is related to
> my previous discussion. The queries generated by my app returns rasters
> with one or two of the borders containing nothing but NODATA values. See
> attached files for an example. The query generated for the sample is:
> ST_GeomFromText('POLYGON((-10401496.01812 5106173.6751207,-10401119.641642
> 5106173.6751207,-10401119.641642 5106363.1552702,-10401496.01812
> 5106173.6751207))',3857)),'AAIGrid',ARRAY['FORCE_CELLSIZE=YES']) FROM
> "dem_elevation" WHERE ST_Intersects(rast,
> ST_Transform(ST_GeomFromText('POLYGON((-10401496.01812
> 5106173.6751207,-10401119.641642 5106173.6751207,-10401119.641642
> 5106363.1552702,-10401496.01812 5106363.1552702,-10401496.01812
> 5106173.6751207))',3857),4269))
> I'm thinking it may have something to do with the partitioning, but I
> couldn't really be sure. Furthermore, I don't think it has anything to do
> with the size of the tiles in the table, because if I shrink the example
> area above, I still get a border of NODATA values.
> Thank you in advance for your assistance!
> <https://docs.google.com/file/d/0By487VT8_JdWSkh5TTdTY2lmWWs/edit?usp=drive_web>
> On Mon, Aug 5, 2013 at 11:13 AM, Jayson Gallardo <jaysontrades at gmail.com>
> wrote:
>> Thanks for your input. I'll try to take a look at your suggestions. I
>> would like to say that I have done some tuning to postgres. Our idea for
>> downloading continental US ned data may be the wrong way to go anyways.
>> Also, forgive me if I seem ignorant to some aspects; I'm a non-traditional
>> college student working for USDA on campus as a programmer, and I'm
>> learning everything as I go. I hope to get to the point where I am on level
>> footing with you all.
>> On Wed, Jul 31, 2013 at 2:51 AM, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Sorry for the double post.
>>> One last thing :
>>> about your query:
>>> you do a ST_clip ( st_union )
>>> You could try a ST_union(st_clip) .
>>> If you have a lot of big rasters it may be faster (??).
>>> Cheers,
>>> Rémi-C
>>> 2013/7/31 Rémi Cura <remi.cura at gmail.com>
>>>> Hey
>>>> Sorry to bother you with technical details, but your query being slow
>>>> may come from hardware, OS, postgres, postgis, bad partitionning, bad
>>>> query, bad index,...
>>>> So can you give more details please?
>>>> What are your versions (OS,postgres, postgis, gdal).
>>>> What is the on disk size of a child table (see statistics)
>>>> How many rows are there in a child table?
>>>> I'm guessing you have an index about envelope of each row.
>>>> What says a EXPLAIN ANALYZE of your query ?
>>>> Quick check list :
>>>> Hardware
>>>> [_] Have you two separate hard disk (one for sys, one for data) / Is
>>>> your disk the bottleneck?
>>>> OS
>>>> [_] What is your system doing when computing a query (look for process,
>>>> memory usage, disk usage)
>>>> [_] Is you OS caching working?
>>>> [_] if linux, have you tun your kernel max memory?
>>>> Postgres
>>>> [_] Have you tuned postgresql.conf conf (very restrictive by default :
>>>> MUST DO).
>>>> Postgis
>>>> [_] ...no idea yet...
>>>> Partitionning
>>>> [_] Are your constraints on child table sufficently restrictive to
>>>> avoid querrying a lots of child table
>>>> [_] Are your constraints used by query planner (explain analyze) .
>>>> If you want to be sure, you can manually explicit it for test purpose :
>>>> adding to WHERE clause "AND st_coveredby(st_convexhull(rast), '
>>>> *...truncated...*'::geometry)) = TRUE
>>>> Query
>>>> [_] I'm guessing you test your query in pgadmin before using python :
>>>> you could start from minimal query (find rasters in a clipping zone
>>>> directly querying a child table), then make it grow (find rasters in father
>>>> table,then compute new raster from previous result, etc), watching how the
>>>> processing time grows in the process.
>>>> Also you should know the computational price of doing ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>>>> that is separate the time to find "rast" intersecting your clipping zone,
>>>> and the time to compute a union and the ST_AsGdalRaster function.
>>>> [_] As suggested, and if you want to avoid sending another query first
>>>> to compute our clipping box, you could use CTE (IE a "WITH" statement), or
>>>> subquery. This way you avoid computing it twice :
>>>> WITH my_clipping_geom AS (
>>>> SELECT ST_Transform(ST_GeomFromText( wkt, map_srs,table_srs)) AS geom
>>>> LIMIT 1
>>>> SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast), my_clipping_geom.geom ,
>>>> raster_type)
>>>> FROM table_name, my_clipping_geom
>>>> WHERE ST_Intersects(rast,my_clipping_geom.geom)
>>>> Index
>>>> [_] You use ST_Intersects, therefore you must have an index to speed it
>>>> up.
>>>> I'm guessing you have one on bounding box of each raster (each line),
>>>> is it used (explain analyze : index scan)
>>>> Don't lose hope, as the whole system can be severly speeded up by
>>>> tuning and small change may have big effects.
>>>> Cheers,
>>>> Rémi-C
>>>> 2013/7/30 Jayson Gallardo <jaysontrades at gmail.com>
>>>>> Thanks for the help again. There will be extensive testing before we
>>>>> go into production. Right now, we're just trying to get a prototype up and
>>>>> running. I might need to look into querying a web service for clipped NED
>>>>> data...
>>>>> On Tue, Jul 30, 2013 at 12:01 PM, Bborie Park <dustymugs at gmail.com>
>>>>> wrote:
>>>>>> That should work if you're querying against the subparent instead of
>>>>>> the parent. You'll need to test though...
>>>>>> -bborie
>>>>>> On Tue, Jul 30, 2013 at 9:59 AM, Jayson Gallardo <
>>>>>> jaysontrades at gmail.com> wrote:
>>>>>>> What if I create subparents for each state, and set an extent
>>>>>>> constraint on each subparent? Would that help? Or would the query still
>>>>>>> check the constraint for each child of each subparent?
>>>>>>> On Tue, Jul 30, 2013 at 11:54 AM, Bborie Park <dustymugs at gmail.com>
>>>>>>> wrote:
>>>>>>>> 3m NED data doesn't exist for the continental US (at least from
>>>>>>>> USGS). But if you were to do so, you could consider a different scheme...
>>>>>>>> 1. All NED files are stored as out-db rasters
>>>>>>>> 2. Each table is for one state, though in some situations you may
>>>>>>>> want more than one table per state (e.g. Texas, California).
>>>>>>>> That should help you keep the # of partitions to a minimum and
>>>>>>>> reduce the size of each partition.
>>>>>>>> -bborie
>>>>>>>> On Tue, Jul 30, 2013 at 9:42 AM, Jayson Gallardo <
>>>>>>>>> I was reading the page on partitioning, and the very last line says*
>>>>>>>>> "**Partitioning using these techniques will work well with up to
>>>>>>>>> perhaps a hundred partitions; don't try to use many thousands of
>>>>>>>>> partitions." *I'm already up to ~400 tables in this partitioning
>>>>>>>>> scheme just for Arkansas and Iowa... Is this a good idea? Would there be a
>>>>>>>>> better way to do the entire continental US?
>>>>>>>>> On Tue, Jul 30, 2013 at 11:39 AM, Bborie Park <dustymugs at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> The quick and dirty approach is to have a query before that query
>>>>>>>>>> that transforms the WKT.
>>>>>>>>>> Something like "SELECT ST_AsEWKT(ST_Transform(...))"
>>>>>>>>>> -bborie
>>>>>>>>>> On Tue, Jul 30, 2013 at 9:35 AM, Jayson Gallardo <
>>>>>>>>>>> I suppose I could do that in my script. How should I go about
>>>>>>>>>>> that? My process is as follows:
>>>>>>>>>>> - User selects area of interest on a map (openlayers)
>>>>>>>>>>> - User clicks submit, and python script is called with the
>>>>>>>>>>> WKT passed as an argument
>>>>>>>>>>> - Python script queries the database, which then outputs the
>>>>>>>>>>> raster
>>>>>>>>>>> - Raster is processed through a library
>>>>>>>>>>> - Processed raster is displayed as an overlay on the map
>>>>>>>>>>> On Tue, Jul 30, 2013 at 11:31 AM, Bborie Park <
>>>>>>>>>>> dustymugs at gmail.com> wrote:
>>>>>>>>>>>> Are you able to transform the wkt before passing it to the sql?
>>>>>>>>>>>> Partitioning only works on constant values, not values that need
>>>>>>>>>>>> processing, e.g. ST_Transform(ST_GeomFromText(\'%s\',%i),%i)).
>>>>>>>>>>>> -bborie
>>>>>>>>>>>> On Tue, Jul 30, 2013 at 9:25 AM, Jayson Gallardo <
>>>>>>>>>>>>> Here's the constraints:
>>>>>>>>>>>>> CONSTRAINT dem_elevation_n33w092_pkey PRIMARY KEY (rid ),
>>>>>>>>>>>>> CONSTRAINT enforce_height_rast CHECK (st_height(rast) =
>>>>>>>>>>>>> 100),
>>>>>>>>>>>>> CONSTRAINT enforce_max_extent_rast CHECK
>>>>>>>>>>>>> (st_coveredby(st_convexhull(rast), '*...truncated...*
>>>>>>>>>>>>> '::geometry)),
>>>>>>>>>>>>> CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) =
>>>>>>>>>>>>> 1),
>>>>>>>>>>>>> CONSTRAINT enforce_out_db_rast CHECK
>>>>>>>>>>>>> (_raster_constraint_out_db(rast) = '{f}'::boolean[]),
>>>>>>>>>>>>> CONSTRAINT enforce_pixel_types_rast CHECK
>>>>>>>>>>>>> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>>>>>>>>>>>>> CONSTRAINT enforce_same_alignment_rast CHECK
>>>>>>>>>>>>> (st_samealignment(rast, '*...truncated...*'::raster)),
>>>>>>>>>>>>> CONSTRAINT enforce_scalex_rast CHECK
>>>>>>>>>>>>> (st_scalex(rast)::numeric(16,10) = 0.000092592592593::numeric(16,10)),
>>>>>>>>>>>>> CONSTRAINT enforce_scaley_rast CHECK
>>>>>>>>>>>>> (st_scaley(rast)::numeric(16,10) = (-0.000092592592593)::numeric(16,10)),
>>>>>>>>>>>>> CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>>>>>>>>>>>>> CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 100)
>>>>>>>>>>>>> and my python script:
>>>>>>>>>>>>> wkt = sys.argv[1] # Polygon shape in WKT format
>>>>>>>>>>>>> raster_type = 'GTiff'
>>>>>>>>>>>>> table_name = 'dem_elevation'
>>>>>>>>>>>>> map_srs = 900913
>>>>>>>>>>>>> table_srs = 4269
>>>>>>>>>>>>> sql_text = 'SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>>>>>>>>>>>>> ST_GeomFromText(\'%s\',%i)),\'%s\') FROM "%s" WHERE
>>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(\'%s\',%i),%i))'
>>>>>>>>>>>>> % (wkt, map_srs, raster_type, table_name, wkt, map_srs,
>>>>>>>>>>>>> table_srs)
>>>>>>>>>>>>> On Tue, Jul 30, 2013 at 11:12 AM, Bborie Park <
>>>>>>>>>>>>>> Jayson,
>>>>>>>>>>>>>> Can you share one of the queries? Also, what check
>>>>>>>>>>>>>> constraints are you using?
>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>> On Tue, Jul 30, 2013 at 7:49 AM, Jayson Gallardo <
>>>>>>>>>>>>>>> So, I used Explain on my SELECT statement, and whether
>>>>>>>>>>>>>>> constraint_exclusion is on or off, it seems to spit out the same number of
>>>>>>>>>>>>>>> rows in the query plan. Is there something I need to do for my table
>>>>>>>>>>>>>>> constraints so that it doesn't do a check on every table I have loaded?
>>>>>>>>>>>>>>> On Tue, Jul 30, 2013 at 9:20 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>> Quick follow up question to my situation... I recently
>>>>>>>>>>>>>>>> loaded 3m resolution NED for Iowa. I have them loaded to one table per
>>>>>>>>>>>>>>>> source tile, and have them inheriting from the parent table that the
>>>>>>>>>>>>>>>> Arkansas NED is inheriting from. Ever since, however, my database seems to
>>>>>>>>>>>>>>>> be running pretty slow. I've run a full vacuum on the data, and there are
>>>>>>>>>>>>>>>> constraints on each table.
>>>>>>>>>>>>>>>> How can I be sure that when I query the parent database
>>>>>>>>>>>>>>>> that it's not querying every single table?
>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 3:14 PM, Bborie Park <
>>>>>>>>>>>>>>>>> I'm just glad to help. Feel free to post your experience,
>>>>>>>>>>>>>>>>> feedback, issues and/or wishes on the mailing-list.
>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 1:10 PM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>> Oh, okay. Yeah you're right about it taking time. I wrote
>>>>>>>>>>>>>>>>>> a python script to generate the raster2pgsql call with the appropriate
>>>>>>>>>>>>>>>>>> table name, so I can just let it run while I do other things. I really
>>>>>>>>>>>>>>>>>> appreciate your help on this. I googled your name and I see you're a pretty
>>>>>>>>>>>>>>>>>> busy person, so I'm glad you're taking the time to answer my questions.
>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 3:05 PM, Bborie Park <
>>>>>>>>>>>>>>>>>>> No. I'm suggesting it later as it does take time and
>>>>>>>>>>>>>>>>>>> separates operations. Get everything imported first and then add
>>>>>>>>>>>>>>>>>>> constraints.
>>>>>>>>>>>>>>>>>>> Having said that, you can do it all at once if so
>>>>>>>>>>>>>>>>>>> desired... just preference depending on volume of import data.
>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 1:02 PM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>>> Okay, is there a specific reason why? As your link
>>>>>>>>>>>>>>>>>>>> states: "raster2pgsql loader uses this function to
>>>>>>>>>>>>>>>>>>>> register raster tables". Are you saying I should specify constraints that
>>>>>>>>>>>>>>>>>>>> will be similar across all tables?
>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:53 PM, Bborie Park <
>>>>>>>>>>>>>>>>>>>>> I'd suggest adding constraints after the fact through
>>>>>>>>>>>>>>>>>>>>> SQL instead of letting raster2pgsql do it.
>>>>>>>>>>>>>>>>>>>>> http://www.postgis.net/docs/manual-2.0/RT_AddRasterConstraints.html
>>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:51 PM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>>>>> So based on the link you provided, and what else I've
>>>>>>>>>>>>>>>>>>>>>> gathered, I first create a parent table:
>>>>>>>>>>>>>>>>>>>>>> CREATE TABLE dem_elevation
>>>>>>>>>>>>>>>>>>>>>> rid integer NOT NULL PRIMARY KEY
>>>>>>>>>>>>>>>>>>>>>> rast raster,
>>>>>>>>>>>>>>>>>>>>>> Then I run raster2pgsql on all the downloaded
>>>>>>>>>>>>>>>>>>>>>> elevation data, sending each input tile to its own table, ie.
>>>>>>>>>>>>>>>>>>>>>> dem_elevation_n36w091. Then alter table to inherit from parent:
>>>>>>>>>>>>>>>>>>>>>> ALTER TABLE dem_elevation_n36w091 INHERIT
>>>>>>>>>>>>>>>>>>>>>> dem_elevation;
>>>>>>>>>>>>>>>>>>>>>> With raster2pgsql taking care of setting the
>>>>>>>>>>>>>>>>>>>>>> constraints for each table. Now, I can just query the parent table
>>>>>>>>>>>>>>>>>>>>>> dem_elevation to get what I need?
>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:33 PM, Bborie Park <
>>>>>>>>>>>>>>>>>>>>>>> I use the USGS NED 10 meter for California with one
>>>>>>>>>>>>>>>>>>>>>>> table for each input raster. In the partitioned table scheme, data tables
>>>>>>>>>>>>>>>>>>>>>>> inherit from a template (parent) table. Queries run on the parent table
>>>>>>>>>>>>>>>>>>>>>>> access the inherited tables.
>>>>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:56 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>>>>>>> Yes, it's usgs ned. And I initially went with one
>>>>>>>>>>>>>>>>>>>>>>>> table for each input tile, but I didn't know how to join (or union) them
>>>>>>>>>>>>>>>>>>>>>>>> together for my query.
>>>>>>>>>>>>>>>>>>>>>>>> On Jul 23, 2013 1:14 PM, "Bborie Park" <
>>>>>>>>>>>>>>>>>>>>>>>>> Can you describe your elevation dataset? Is it
>>>>>>>>>>>>>>>>>>>>>>>>> USGS NED? At which resolution (10 meter, 3 meter?)?
>>>>>>>>>>>>>>>>>>>>>>>>> As for table partitioning...
>>>>>>>>>>>>>>>>>>>>>>>>> http://www.postgresql.org/docs/9.0/static/ddl-partitioning.html
>>>>>>>>>>>>>>>>>>>>>>>>> You'll probably partition spatially, though an
>>>>>>>>>>>>>>>>>>>>>>>>> easy solution is to have a table for each input raster file.
>>>>>>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:05 AM, Jayson Gallardo
>>>>>>>>>>>>>>>>>>>>>>>>> <jaysontrades at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks for responding. Could you outline how I
>>>>>>>>>>>>>>>>>>>>>>>>>> would go about doing a partitioned table structure? My only concern with
>>>>>>>>>>>>>>>>>>>>>>>>>> tile size is processing time. Most of my queries will involve areas of less
>>>>>>>>>>>>>>>>>>>>>>>>>> than 1 mi^2, and I would clip the data into that shape. I just don't know
>>>>>>>>>>>>>>>>>>>>>>>>>> where to start! There's not too many resources online/print dealing with
>>>>>>>>>>>>>>>>>>>>>>>>>> postgis rasters in detail.
>>>>>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:57 PM, Bborie Park <
>>>>>>>>>>>>>>>>>>>>>>>>>>> You may not need to drop all the constraints
>>>>>>>>>>>>>>>>>>>>>>>>>>> when adding additional data to the table. You most likely will need to drop
>>>>>>>>>>>>>>>>>>>>>>>>>>> is the maximum extent constraint. Assuming the input rasters have the same
>>>>>>>>>>>>>>>>>>>>>>>>>>> scale, skew and SRID as that found in the table, you don't need to drop
>>>>>>>>>>>>>>>>>>>>>>>>>>> those corresponding constraints.
>>>>>>>>>>>>>>>>>>>>>>>>>>> If you're going to do the continental US at a
>>>>>>>>>>>>>>>>>>>>>>>>>>> fine resolution (e.g. 1 meter), you do NOT want to put all the rasters in
>>>>>>>>>>>>>>>>>>>>>>>>>>> one table. You'll want to use a partitioned table structure and should
>>>>>>>>>>>>>>>>>>>>>>>>>>> consider a bigger tile size (depending on your hardware).
>>>>>>>>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 10:43 AM, Jayson
>>>>>>>>>>>>>>>>>>>>>>>>>>> Gallardo <jaysontrades at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> I've looked and looked, but I have not been
>>>>>>>>>>>>>>>>>>>>>>>>>>>> able to find an answer to my question. I have downloaded elevation data for
>>>>>>>>>>>>>>>>>>>>>>>>>>>> the state of Arkansas (in the form of multiple tiles), and used
>>>>>>>>>>>>>>>>>>>>>>>>>>>> raster2pgsql to upload it into a single table:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> raster2pgsql -I -C -e -F -t 50x50 -l 2,4
>>>>>>>>>>>>>>>>>>>>>>>>>>>> n*/grdn* public.dem_elevation | psql -U postgres -d testdb -h localhost -p
>>>>>>>>>>>>>>>>>>>>>>>>>>>> 5432
>>>>>>>>>>>>>>>>>>>>>>>>>>>> I did this because I didn't know how to pull
>>>>>>>>>>>>>>>>>>>>>>>>>>>> the data if they were in separate tables. Now, however I would like to add
>>>>>>>>>>>>>>>>>>>>>>>>>>>> elevation data for other areas. I tried to just add it to the current
>>>>>>>>>>>>>>>>>>>>>>>>>>>> table, but that required dropping the constraints which for such a huge
>>>>>>>>>>>>>>>>>>>>>>>>>>>> amount of data seems to take a long time (I let it run for 24+ hours and it
>>>>>>>>>>>>>>>>>>>>>>>>>>>> didn't finish). So, my question is, if I load all my rasters as individual
>>>>>>>>>>>>>>>>>>>>>>>>>>>> tables, how could I run something similar to this query on them all (from a
>>>>>>>>>>>>>>>>>>>>>>>>>>>> python script):
>>>>>>>>>>>>>>>>>>>>>>>>>>>> ST_GeomFromText(WKT,900913)),'GTiff') FROM "dem_elevation" WHERE
>>>>>>>>>>>>>>>>>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(WKT,900913),4269))
>>>>>>>>>>>>>>>>>>>>>>>>>>>> My goal, if it's not obvious, is to clip
>>>>>>>>>>>>>>>>>>>>>>>>>>>> elevation data and export it to a GTiff format and perform some operations
>>>>>>>>>>>>>>>>>>>>>>>>>>>> on that raster data. Eventually, I would like to put the whole continental
>>>>>>>>>>>>>>>>>>>>>>>>>>>> US elevation data into my database, so I need to be able to do so, while
>>>>>>>>>>>>>>>>>>>>>>>>>>>> still being able to query them based on an area of interest the user
>>>>>>>>>>>>>>>>>>>>>>>>>>>> selects from a map. I started working with PostGIS and Mapserver last
>>>>>>>>>>>>>>>>>>>>>>>>>>>> month, so please forgive my ignorance on such topics. Thanks in advance
>>>>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140602/79aa2bdc/attachment.html>
