[postgis-users] Spike finder
Birgit Laggner
birgit.laggner at ti.bund.de
Fri Jun 13 03:52:53 PDT 2014
Hi L.
I would suspect the first assignment of the result_pnt (result_pnt :=
ST_Collect(result_pnt, st_pointn(lineusp, point_id));) as the cause of
the problem: Within your assignment, you try to use the geometry of
result_pnt which does not yet exist at this moment. Maybe, you could
work with an IF clause to assign some sort of start value to your
result_pnt variable.
Regards,
Birgit.
Am 11.06.2014 10:56, schrieb Pier Lorenzo Marasco:
> I tried to modify spikeRemover from Schmidt & Krüger to obtain just
> the spike position. For some reason, that I can't figure out, my
> script fails and I don't obtain a multipoint position. Probably there
> is a problem in the aggregation of different points but I don't know
> how to manage it in another way. I tried with ST_collect and ST_union
> but with both I don't obtain a right geometry.
> CREATE OR REPLACE FUNCTION ST_SpikeFinder (geometry, angle double
> precision)
> returns geometry as
> $body$
> DECLARE
> ingeom alias for $1;
> angle alias for $2;
> lineusp geometry;
> newgeom geometry;
> numpoints integer;
> point_id integer;
> result_pnt geometry;
> begin
> -- input geometry or rather set as default for the output
> newgeom := ingeom;
> -- check polygon
> if (select st_geometrytype(ingeom)) = 'ST_Polygon' then
> if (select st_numinteriorrings(ingeom)) = 0 then
> lineusp := st_boundary(ingeom) as line;
> numpoints := st_numpoints(lineusp);
> point_id := 0;
> -- the geometry passes pointwisely
> while (point_id <= numpoints) loop
> result_pnt := ST_Collect(result_pnt,
> -- the check of the angle at the current point of
> a spike including the special case, that it is the first point.
> if (select abs(pi() -
> abs(st_azimuth(st_pointn(lineusp, case when point_id= 1 then
> st_numpoints(lineusp) - 1 else point_id - 1 end),
> st_pointn(lineusp, point_id)) -
> st_azimuth(st_pointn(lineusp, point_id), st_pointn(lineusp, point_id +
> 1))))) <= angle then
> (probably the problem is here) ---> result_pnt :=
> ST_Union(result_pnt, st_pointn(lineusp, point_id));
> end if;
> point_id = point_id + 1;
> end loop;
> end if;
> end if;
> return result_pnt;
> end;
> $body$
> language 'plpgsql' volatile;
> Any idea ?
> Thank you in advance.
> L.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140613/6ab31055/attachment.html>
