[postgis-users] Point clustering function/algorithms
Rémi Cura remi.cura at gmail.com
Sun Jun 22 09:13:46 PDT 2014
The obvious answer here is to use PLR/R (http://www.joeconway.com/plr/).
There are many many ways to perform clustering (
http://cran.r-project.org/web/views/Cluster.html),
be it supervised or un-supervised, or even using machine learning (
http://cran.r-project.org/web/views/MachineLearning.html).
So the easiest way is install plr (very easy on linux/mac/win), R, then try
one of the hundred of methods available  based on your requirement.
As a bonus you can plot easily the result. I tried this and it took may few
days total to have a working tool (no previous knowledge of R).
You have an entire task view dedicated to spatial data in R (
http://cran.r-project.org/web/views/Spatial.html).
On an other end, and if you feel adventurous, you could try MadLib :
http://madlib.net/ (NEED 64b !), which answers exactly to your needs.
Cheers,
Rémi-C
2014-06-22 15:29 GMT+02:00 Travis Kirstine <traviskirstine at gmail.com>:
> The kneans that I have seen used is loaded as a additional function and
> does not require you to recompile
> On Sunday, June 22, 2014, Miguel-Angel Manso-Callejo (UPM) <m.manso at upm.es>
> wrote:
>> Dear all,
>> I am interesting on perform spatio/temporal clustering of points
>> geometries stored in a postgis layer.
>> I have looked for any posssible solution implemented in postgis and i
>> have not found any one.
>> I have seen some discussion and proposal based on building a new function
>> kmeans for postgresql, but this solution require compile postgresql.
>> Other solution that i have tryed is a pgplsql function that compute
>> convexhull of points that not distance more than X m.
>> My question is:
>> Have you any alternative solution or have developed more pgplsql
>> functions to do perform point clustering in postgis?
>> Regards,
>> Miguel A. Manso
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140622/e3958c0f/attachment.html>
