[postgis-users] Recording problems with PostGIS
benebrice
brice.bene at gmail.com
Tue Mar 4 07:34:31 PST 2014
Hello,
I am currently developing a Rails Application (Rails 4.0.2, Ruby 2.1). I am
using RGeo to convert longitude and latitude to a position with the srid
3785 (for PostGIS). When I am on with the terminal, I can project and
unproject the coordinates without any problem. But when I save the position
on PostgreSQL and try to unproject the position, I have an error coming from
RGeo.
I already posted an issue on the github RGeo - Issue#65
<https://github.com/dazuma/rgeo/issues/65> . Overthere everything is well
explained.
I am completely blocked on my development because of this error.
I have installed PostGis via PostgresApp <http://postgresapp.com> with
the following code lines to create a template before the migration with
Rails according to this template.
sudo su postgres
createdb template_postgis
createlang plpgsql template_postgis
psql -d template_postgis -f
/Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/postgis.sql
/Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/spatial_ref_sys.sql
If anyone has an idea to unblock me, I would really appreciate it.
Thank you in advance.
Regards,
View this message in context: http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
