[postgis-users] Recording problems with PostGIS
Margie Roswell
mroswell at gmail.com
Tue Mar 4 07:36:43 PST 2014
Maybe this is it?
http://alastaira.wordpress.com/2011/01/23/the-google-maps-bing-maps-spherical-mercator-projection/
"However, less than a year after the official EPSG: 3785 code was finally
introduced, EPSG issued a change request (EPSG::2008.114, issued in Dec
2008), deprecating the 3785 code and introducing a new code, 3857, with
corresponding parameters..."
http://FarmBillPrimer.org
http://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
http://www.ExcellentNutrition.org
http://www.packtpub.com/drupal-5-views-recipes/book
On Tue, Mar 4, 2014 at 10:34 AM, benebrice <brice.bene at gmail.com> wrote:
> Hello,
> I am currently developing a Rails Application (Rails 4.0.2, Ruby 2.1). I am
> using RGeo to convert longitude and latitude to a position with the srid
> 3785 (for PostGIS). When I am on with the terminal, I can project and
> unproject the coordinates without any problem. But when I save the position
> on PostgreSQL and try to unproject the position, I have an error coming
> from
> RGeo.
> I already posted an issue on the github RGeo - Issue#65
> <https://github.com/dazuma/rgeo/issues/65> . Overthere everything is well
> explained.
> I am completely blocked on my development because of this error.
> I have installed PostGis via PostgresApp <http://postgresapp.com> with
> the following code lines to create a template before the migration with
> Rails according to this template.
> sudo su postgres
> createdb template_postgis
> createlang plpgsql template_postgis
> psql -d template_postgis -f
> /Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/postgis.sql
> /Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/spatial_ref_sys.sql
> If anyone has an idea to unblock me, I would really appreciate it.
> Thank you in advance.
> Regards,
> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140304/21657425/attachment.html>
