[postgis-users] Recording problems with PostGIS
benebrice brice.bene at gmail.com
Tue Mar 4 09:33:37 PST 2014
Thank you for your answer but unfortunately I had already tried this. I did
it again but still nothing. I used a similar configuration with a Rails 3
Application and Ruby 1.9.2 with PostiGIS 2. It was working. I may have done
something but I am not able to remember what. I checked everything on my
previous code but still nothing. Maybe my configuration of PostGIS on Mac
OS X (previously it was Ubuntu 12.04) is bad. Is there something wrong or
missing in my process described previously ?
Thank you again for you time.
*Brice.*
2014-03-04 16:38 GMT+01:00 Margie Roswell [via PostGIS] <
ml-node+s17n5005822h21 at n6.nabble.com>:
> Maybe this is it?
> http://alastaira.wordpress.com/2011/01/23/the-google-maps-bing-maps-spherical-mercator-projection/
> "However, less than a year after the official EPSG: 3785 code was finally
> introduced, EPSG issued a change request (EPSG::2008.114, issued in Dec
> 2008), deprecating the 3785 code and introducing a new code, 3857, with
> corresponding parameters..."
> http://FarmBillPrimer.org
> http://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
> http://www.ExcellentNutrition.org
> http://www.packtpub.com/drupal-5-views-recipes/book
> On Tue, Mar 4, 2014 at 10:34 AM, benebrice <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005822&i=0>
> > wrote:
>> Hello,
>> I am currently developing a Rails Application (Rails 4.0.2, Ruby 2.1). I
>> am
>> using RGeo to convert longitude and latitude to a position with the srid
>> 3785 (for PostGIS). When I am on with the terminal, I can project and
>> unproject the coordinates without any problem. But when I save the
>> position
>> on PostgreSQL and try to unproject the position, I have an error coming
>> from
>> RGeo.
>> I already posted an issue on the github  RGeo - Issue#65
>> <https://github.com/dazuma/rgeo/issues/65>  . Overthere everything is
>> well
>> explained.
>> I am completely blocked on my development because of this error.
>> I have installed PostGis via  PostgresApp <http://postgresapp.com>   with
>> the following code lines to create a template before the migration with
>> Rails according to this template.
>> sudo su postgres
>> createdb template_postgis
>> createlang plpgsql template_postgis
>> psql -d template_postgis -f
>> /Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/postgis.sql
>> /Applications/Postgres93.app/Contents/MacOS/share/postgresql/contrib/postgis-2.1/spatial_ref_sys.sql
>> If anyone has an idea to unblock me, I would really appreciate it.
>> Thank you in advance.
>> Regards,
>> View this message in context:
>> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005822&i=1>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005822&i=2>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005822.html
>  To unsubscribe from Recording problems with PostGIS, click here<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5005821&code=YnJpY2UuYmVuZUBnbWFpbC5jb218NTAwNTgyMXwxMDczODc4MDc4>
> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005825.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140304/5a2aa34c/attachment.html>
