[postgis-users] Recording problems with PostGIS
Dan Lyke danlyke at flutterby.com
Tue Mar 4 09:38:28 PST 2014
On Tue, Mar 4, 2014 at 9:33 AM, benebrice <brice.bene at gmail.com> wrote:
> Thank you for your answer but unfortunately I had already tried this. I did
> it again but still nothing. I used a similar configuration with a Rails 3
> Application and Ruby 1.9.2 with PostiGIS 2. It was working.
Is there perhaps a way to dump the SQL that your Rails ORM is
generating? Seems to me like you've got a leaky abstraction layer
somewhere, the problem is likely in Rails, and without knowing how
Rails is going wrong we're just playing pin the tail on the donkey.
Dan
