[postgis-users] Recording problems with PostGIS
benebrice
brice.bene at gmail.com
Tue Mar 4 12:42:59 PST 2014
I tried to create the database manually with the template and only after
does the migrations. I check the value before being recorded and it is ok
(I can obviously unproject the projection). But when it is stored, it
cannot be unproject. The problem can come from 2 different points.
The activerecord-postgis-adapter/rgeo-activerecord or PostGIS. I think
Rails 4 is a possible reason of that.
*Brice.*
2014-03-04 18:38 GMT+01:00 Dan Lyke [via PostGIS] <
ml-node+s17n5005826h45 at n6.nabble.com>:
> On Tue, Mar 4, 2014 at 9:33 AM, benebrice <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005826&i=0>>
> wrote:
> > Thank you for your answer but unfortunately I had already tried this. I
> did
> > it again but still nothing. I used a similar configuration with a Rails
> 3
> > Application and Ruby 1.9.2 with PostiGIS 2. It was working.
> Is there perhaps a way to dump the SQL that your Rails ORM is
> generating? Seems to me like you've got a leaky abstraction layer
> somewhere, the problem is likely in Rails, and without knowing how
> Rails is going wrong we're just playing pin the tail on the donkey.
> Dan
> postgis-users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005826&i=1>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005826.html
> To unsubscribe from Recording problems with PostGIS, click here<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5005821&code=YnJpY2UuYmVuZUBnbWFpbC5jb218NTAwNTgyMXwxMDczODc4MDc4>
> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005829.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140304/69512c86/attachment.html>
