[postgis-users] PostGIS heatmap generation
Paul Norman
penorman at mac.com
Mon Mar 17 15:41:03 PDT 2014
I'm looking at heatmap generation with PostGIS and was wondering if anyone
had any suggestions.
To give some specifics to the problem
- I have a dataset of 100 million to 500 million points
across the US
- Each point has a date associated with it
- The data covers the US
- The data is to be loaded in from text files
- Everything has to be able to run from the command line
without user interaction
- The data will be viewed on a state level down to a local
level through a webmap
I want to make heatmaps for questions like "points in the
last week" or "points in the last month"
I've looked at a few common suggestions for heatmaps
Leaflet.heatmap: Millions of points is out of the question
QGIS heatmap plugin: As far as I can tell, this requires user
interaction and is out of the question.
R: I don't know R, but I think it'd suffer the same problems as
Mapnik does, below.
Mapnik (https://www.mapbox.com/blog/colorize-alpha-image-filter/):
I got this working with some test data (OSM nodes table) and it
works up to a point. When I start requesting areas with hundreds
of thousands of points it starts to bog down. I'm not sure if this
exclusively on the query side or also on the rendering side.
One potential problem is that at low zooms I'd be returning millions
of rows from PostgreSQL.
Has anyone got any suggestions for how to efficiently render heatmaps
from datasets this large? I was thinking of two tables, one with the
raw data for high zooms and one pre-aggregated into space and time
bins (e.g. requests in a given box in a given time range) for use
in lower zooms. The aggregation operation would obviously be slow, but
I'd only have to do it once.
