[postgis-users] PostGIS heatmap generation
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 17 16:26:20 PDT 2014
Server-side heat-mapping will get you closer, but still might find
"millions" to be a tall order to do interactively.
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html
Depends on how much you can filter those 500M records down. You won't
be doing them all, that's for sure!
P.
On Mon, Mar 17, 2014 at 3:41 PM, Paul Norman <penorman at mac.com> wrote:
> I'm looking at heatmap generation with PostGIS and was wondering if anyone
> had any suggestions.
> To give some specifics to the problem
> - I have a dataset of 100 million to 500 million points
> across the US
> - Each point has a date associated with it
> - The data covers the US
> - The data is to be loaded in from text files
> - Everything has to be able to run from the command line
> without user interaction
> - The data will be viewed on a state level down to a local
> level through a webmap
> I want to make heatmaps for questions like "points in the
> last week" or "points in the last month"
> I've looked at a few common suggestions for heatmaps
> Leaflet.heatmap: Millions of points is out of the question
> QGIS heatmap plugin: As far as I can tell, this requires user
> interaction and is out of the question.
> R: I don't know R, but I think it'd suffer the same problems as
> Mapnik does, below.
> Mapnik (https://www.mapbox.com/blog/colorize-alpha-image-filter/):
> I got this working with some test data (OSM nodes table) and it
> works up to a point. When I start requesting areas with hundreds
> of thousands of points it starts to bog down. I'm not sure if this
> exclusively on the query side or also on the rendering side.
> One potential problem is that at low zooms I'd be returning millions
> of rows from PostgreSQL.
> Has anyone got any suggestions for how to efficiently render heatmaps
> from datasets this large? I was thinking of two tables, one with the
> raw data for high zooms and one pre-aggregated into space and time
> bins (e.g. requests in a given box in a given time range) for use
> in lower zooms. The aggregation operation would obviously be slow, but
> I'd only have to do it once.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
