[postgis-users] PostGIS heatmap generation
Sandro Santilli
strk at keybit.net
Tue Mar 18 00:40:41 PDT 2014
On Mon, Mar 17, 2014 at 03:41:03PM -0700, Paul Norman wrote:
> - I have a dataset of 100 million to 500 million points
> across the US
> Has anyone got any suggestions for how to efficiently render heatmaps
> from datasets this large? I was thinking of two tables, one with the
> raw data for high zooms and one pre-aggregated into space and time
> bins (e.g. requests in a given box in a given time range) for use
> in lower zooms. The aggregation operation would obviously be slow, but
> I'd only have to do it once.
Pre-aggregation would surely help, big problem being amount
of records that need to be read from disk. You could also look
at postgis raster as the aggregation type.
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
