[postgis-users] Accessing lots of missing outdb/offline rasters appear to cause PostgreSQL to crash
Bborie Park
dustymugs at gmail.com
Mon Mar 31 09:51:07 PDT 2014
Strange that you're getting a process termination. The problem with loading
out-db rasters was just resolved in 2.0.5 and 2.1.2...
http://postgis.net/2014/03/31/postgis-2.1.2
The specific ticket is #2607...
Can you trying upgrading and see if the problem persists? I've never seen
the process terminate whenever I've hit the open file limit.
-bborie
On Mon, Mar 31, 2014 at 9:44 AM, Robert Nix <robert at urban4m.com> wrote:
> After 1001 of these errors:
> 2014-03-31 15:50:51 UTC ERROR: rt_band_load_offline_data: Cannot open
> offline raster: /...
> I get:
> SELECT: rt_api.c:8659: rt_raster_from_band: Assertion `((void *)0) !=
> raster' failed.
> 2014-03-31 15:50:52 UTC LOG: server process (PID 8385) was terminated by
> signal 6: Aborted
> Eventually resulting in:
> 2014-03-31 15:50:52 UTC FATAL: the database system is in recovery mode
> Requiring bouncing the postgres service.
> I'm not sure if this is an issue with PostGIS or PostgreSQL itself.
> I'm accessing the rasters from within a sql function, essentially:
> st_setbandnodatavalue(
> st_snaptogrid(
> st_setsrid(_rast,4326),
> gridx:=st_upperleftx(_rast),
> gridy:=st_upperlefty(_rast)
> 0.0
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/b1c3380b/attachment.html>
