[postgis-users] Accessing lots of missing outdb/offline rasters appear to cause PostgreSQL to crash
Robert Nix robert at urban4m.com
Mon Mar 31 20:01:31 PDT 2014
Upgraded:
POSTGIS="2.1.2 r12389" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" (core procs
from "2.1.1 r12113" need upgrade) TOPOLOGY (topology procs from "2.1.1
r12113" need upgrade) RASTER (raster procs from "2.1.1 r12113" need upgrade)
Unfortunately, *the problem persists* though the scenario is slightly
different. Specifically, it appears to be unrelated to inaccessible offline
rasters since the issue is now occurring even while all offline rasters are
accessible. But it may be due to any SQL exception occurring during the
processing of SQL that contains raster functions. In other words, I am
doing an insert that contains calls to functions that execute SQL like that
in my original post. In some cases, an exception (duplicate key) is
occurring and almost immediately following that error is the rt_raster_from_band:
Assertion. And it's consistent. If the duplicate key error occurs, the
assertion follows. The only other times i see the assertion seems to be
related to recovery attempts.
If the assertion occurs more than a few dozen times, the database goes into
a permanent "recovery mode" outputting nothing else to the log except the
recovery message several times a second until i can stop the postgresql
service.
On Monday, March 31, 2014 12:44:00 PM UTC-4, Robert Nix wrote:
> After 1001 of these errors:
> 2014-03-31 15:50:51 UTC ERROR:  rt_band_load_offline_data: Cannot open
> offline raster: /...
> I get:
> SELECT: rt_api.c:8659: rt_raster_from_band: Assertion `((void *)0) !=
> raster' failed.
> 2014-03-31 15:50:52 UTC LOG:  server process (PID 8385) was terminated by
> signal 6: Aborted
> Eventually resulting in:
> 2014-03-31 15:50:52 UTC FATAL:  the database system is in recovery mode
> Requiring bouncing the postgres service.
> I'm not sure if this is an issue with PostGIS or PostgreSQL itself.
> I'm accessing the rasters from within a sql function, essentially:
> st_setbandnodatavalue(
>   st_snaptogrid(
>     st_setsrid(_rast,4326),
>     gridx:=st_upperleftx(_rast),
>     gridy:=st_upperlefty(_rast)
>   0.0
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/8642691f/attachment-0001.html>
