[postgis-users] PostGIS 2.1.2 and 2.0.5 released
Gerry Creager - NOAA Affiliate
gerry.creager at noaa.gov
Mon Mar 31 09:57:35 PDT 2014
Does your first line imply that temperatures have risen above the freezing
level, for at least carbon dioxide, north of, say, Chicago?
On Mon, Mar 31, 2014 at 8:40 AM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> Hi all,
> Spring is here (in the northern hemisphere, mostly) and that means it's
> time to release some fresh patch releases of PostGIS 2.1 and 2.0 branches!
> http://download.osgeo.org/postgis/source/postgis-2.1.2.tar.gz
> http://download.osgeo.org/postgis/source/postgis-2.0.5.tar.gz
> For detailed changes, check out the respective release notes:
> http://svn.osgeo.org/postgis/tags/2.1.2/NEWS
> http://svn.osgeo.org/postgis/tags/2.0.5/NEWS
> Users of the 2.1 branch should strongly consider upgrading: there are some
> crashers fixed in this release, and there are important fixes to the
> geography (spherical) distance calculations that repair incorrect handling
> of multi-geometries. Remember this is a patch release, so upgrading just
> involves installing the new software, you don't need to do a dump and
> restore, just install and "ALTER EXTENSION postgis UPDATE TO '2.1.2';
> Thanks!
> Your PostGIS PSC
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Gerry Creager
NSSL/CIMMS
405.325.6371
"Big whorls have little whorls,
That feed on their velocity;
And little whorls have lesser whorls,
And so on to viscosity."
Lewis Fry Richardson (1881-1953)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/0f59517b/attachment.html>
