[postgis-users] PostGIS 2.1.2 and 2.0.5 released
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 31 11:24:09 PDT 2014
Tulips and cherry blossoms here in God's land.
If you chose the wrong place to live, there's not much we can do for you... :)
http://en.es-static.us/upl/2014/03/north-america-winter-2014.jpg
On Mon, Mar 31, 2014 at 9:57 AM, Gerry Creager - NOAA Affiliate
<gerry.creager at noaa.gov> wrote:
> Does your first line imply that temperatures have risen above the freezing
> level, for at least carbon dioxide, north of, say, Chicago?
> On Mon, Mar 31, 2014 at 8:40 AM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Hi all,
>> Spring is here (in the northern hemisphere, mostly) and that means it's
>> time to release some fresh patch releases of PostGIS 2.1 and 2.0 branches!
>> http://download.osgeo.org/postgis/source/postgis-2.1.2.tar.gz
>> http://download.osgeo.org/postgis/source/postgis-2.0.5.tar.gz
>> For detailed changes, check out the respective release notes:
>> http://svn.osgeo.org/postgis/tags/2.1.2/NEWS
>> http://svn.osgeo.org/postgis/tags/2.0.5/NEWS
>> Users of the 2.1 branch should strongly consider upgrading: there are some
>> crashers fixed in this release, and there are important fixes to the
>> geography (spherical) distance calculations that repair incorrect handling
>> of multi-geometries. Remember this is a patch release, so upgrading just
>> involves installing the new software, you don't need to do a dump and
>> restore, just install and "ALTER EXTENSION postgis UPDATE TO '2.1.2';
>> Thanks!
>> Your PostGIS PSC
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
> "Big whorls have little whorls,
> That feed on their velocity;
> And little whorls have lesser whorls,
> And so on to viscosity."
> Lewis Fry Richardson (1881-1953)
