[postgis-users] PostGIS 2.1.2 and 2.0.5 released
Gerry Creager - NOAA Affiliate gerry.creager at noaa.gov
Mon Mar 31 12:45:43 PDT 2014
I'm not sure I'd call it God's country (on either your part or mine). I
chose to live in Oklahoma because... that's where the severe storms are.
On Mon, Mar 31, 2014 at 1:24 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> Tulips and cherry blossoms here in God's land.
> If you chose the wrong place to live, there's not much we can do for
> you... :)
> http://en.es-static.us/upl/2014/03/north-america-winter-2014.jpg
> On Mon, Mar 31, 2014 at 9:57 AM, Gerry Creager - NOAA Affiliate
> <gerry.creager at noaa.gov> wrote:
> > Does your first line imply that temperatures have risen above the
> freezing
> > level, for at least carbon dioxide, north of, say, Chicago?
> > On Mon, Mar 31, 2014 at 8:40 AM, Paul Ramsey <pramsey at cleverelephant.ca>
> > wrote:
> >> Hi all,
> >> Spring is here (in the northern hemisphere, mostly) and that means it's
> >> time to release some fresh patch releases of PostGIS 2.1 and 2.0
> branches!
> >>   http://download.osgeo.org/postgis/source/postgis-2.1.2.tar.gz
> >>   http://download.osgeo.org/postgis/source/postgis-2.0.5.tar.gz
> >> For detailed changes, check out the respective release notes:
> >>   http://svn.osgeo.org/postgis/tags/2.1.2/NEWS
> >>   http://svn.osgeo.org/postgis/tags/2.0.5/NEWS
> >> Users of the 2.1 branch should strongly consider upgrading: there are
> some
> >> crashers fixed in this release, and there are important fixes to the
> >> geography (spherical) distance calculations that repair incorrect
> handling
> >> of multi-geometries. Remember this is a patch release, so upgrading just
> >> involves installing the new software, you don't need to do a dump and
> >> restore, just install and "ALTER EXTENSION postgis UPDATE TO '2.1.2';
> >> Thanks!
> >> Your PostGIS PSC
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> > Gerry Creager
> > NSSL/CIMMS
> > 405.325.6371
> > "Big whorls have little whorls,
> > That feed on their velocity;
> > And little whorls have lesser whorls,
> > And so on to viscosity."
> > Lewis Fry Richardson (1881-1953)
Gerry Creager
NSSL/CIMMS
405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/2b464de0/attachment.html>
