[postgis-users] raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
Guillaume Drolet
droletguillaume at gmail.com
Fri May 2 12:47:40 PDT 2014
Regina,
When I do
SELECT postgis_full_version();
It says (from what I remember. I won't have access to my database
until next week) :
GDAL 1.11dev (of course if my 1.11dev installation is at the place
described by the GDAL variable). If my GDAL installation is moved as I
did in my previous post, the GDAL version shown by SELECT
postgis_full_version(); is 1.10.
So it looks like a problem with raster2pgsql and rather than with
PostGIS as the loading of the SQL file from raster2pgsql runs fine. I
don't know who maintains this program but maybe it'd be worth checking
it against versions of GDAL after 1.10.
Regards,
Guillaume
> Message: 2
> Date: Wed, 30 Apr 2014 21:24:06 -0400
> From: "Paragon Corporation" <lr at pcorp.us>
> To: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on
> Message-ID: <B32609B07B7A4065BCB2823C48B3F6C5 at O>
> Content-Type: text/plain; charset="us-ascii"
> Guillaume,
> It was my understanding that PostGIS only uses the libgdal in the same
> folder as raster2pgsql since that would be the first in its path. However it
> uses the environment variable for the proj files and so forth. So I'm still
> a bit surprised this is an issue unless those files are vastly different
> from 1.10.
> When you do
> What does it give for the GDAL version.
> If its just a during load problem, I think you can just simply override the
> environment variable in your loader batch script
> SET GDAL_DATA="C:\Program Files\PostgreSQL\9.3\gdal-data"
> Of course this won't fix your running install. In PostGIS 2.2 we introduced
> a PostgreSQL GUC variable to handle this:
> http://postgis.net/docs/manual-dev/postgis_gdal_datapath.html
> But unfortunately that won't help you for 2.1 and not sure how much that
> helps with raster2pgsql anyway since I don't think raster2pgsql makes
> connection to Postgres to be able to even see that variable.
> What I could do is create a build that uses the newer GDAL to see if that
> improves your situation (you can be my test guinea pig :) ). IN 2.2 I plan
> to ship with GDAL 1.11 and probably upgrade next 2.1 to GDAL 1.11 as well
> since unfortunately they have to share the same GDAL on same PostgreSQL
> install and some people I expect will be running both.
> Opinions?
> Regina
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
> Sent: Wednesday, April 30, 2014 4:39 PM
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit
> Hi Regina and others:
> We found the problem with raster2pgsql! It was my version of GDAL
> (1.11dev) that my GDAL environment variable was pointing to that created the
> bug. I simply moved my GDAL folder to some other location (without changing
> GDAL environment variable) and ran raster2pgsql again so that PostGIS could
> use its own GDAL instead. This resulted in a complete (i.e. no broken line
> at the end) output SQL file from raster2pgsql.
> Since I want to keep using my GDAL version (1.11dev, with all my add-ons
> compiled and the version used by other software), this raises the question:
> how to force PostGIS to not use the GDAL installation referenced by the GDAL
> environment variable but instead use its own GDAL?
> Thanks!
> G
> 2014-04-30 15:00 GMT-04:00 <postgis-users-request at lists.osgeo.org>:
>> Send postgis-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> postgis-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of postgis-users digest..."
>> Today's Topics:
>> 1. Re: Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit -
>> ERREUR: erreur de syntaxe (Paragon Corporation)
>> Message: 1
>> Date: Tue, 29 Apr 2014 18:51:16 -0400
>> Message-ID: <40C3ECB89B9F4C388A6CE0F390D877C5 at O>
>> Guillaume,
>> Did you say this works fine on your home pc, but not your work one?
>> I'm wondering if maybe its some malware or virus checker shutting down
>> the execution of raster2pgsql for some reason.
>> Have you looked at the windows event viewer to see if it is showing
>> any messages? I recall one time a behind the scenes VMWare virus
>> checker kept on deleting some of my Msys files because it thought it
>> was hacker ware. No duh. Had to tell sysadmins to exclude the folder from
> their checking.
>> Hope that helps,
>> Regina
>> Drolet
>> Sent: Monday, April 28, 2014 2:30 PM
>> 64bit
>> Hi Mateusz,
>> Thanks for helping. What you suggested, i.e. outputting raster2pgsql
>> to an SQL file instead of piping it to psql, I have done already. I
>> also posted examples of where the lines are broken in previous post
>> (see also Jean-Daniel Sylvain's older post on the same topic).
>> It doesn't seem to break on non-ASCII characters. For example, this
>> one breaks in the middle of the file name at line 168:
>> INSERT INTO "mod09a1.a2000049.h12v04.005.2006268184041_sur_refl_b01"
>> ("rast","filename") VALUES
>> ('0100000100A544B7031A11713FA544B7031A1171BF86BE196C857752C095AFEE8CEE
>> 6E4740
>> 00000000000000000000000000000000E610000032001F008700000000004D4F443039
>> 41312E
>> 41323030303034392E6831327630342E3030352E323030363236383138343034315F73
>> 75725F
>> 7265666C5F6230312E74696600'::raster,'MOD09A1.A2000049.h12v04.005.20062
>> 681840
>> 41_sur_refl_b01.tif');
>> ('0100000100A544B7031A11713FA544B7031A1171BF59D7C60F306A52C095AFEE8CEE
>> 6E4740
>> 41312E
>> 75725F
>> 681840
>> ('0100000100A544B7031A11713FA544B7031A1171BF2BF073B3DA5C52C095AFEE8CEE
>> 6E4740
>> 41312E
>> 75725F
>> 681840
>> Or, this one (same tif file; I only shortened the filename) breaks in
>> the middle of a cell (or tile?) representation, still at line 168:
>> INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
>> 6E4740
>> 41312E
>> 41323030303034392E7375725F7265666C5F6230312E74696600'::raster,'MOD09A1
>> .A2000
>> 049.sur_refl_b01.tif');
>> INSERT INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
>> 6E4740
>> 41312E
>> .A2000
>> 6E4740
>> 41312E
>> .A2000
>> This is VERY frustrating and I hope an answer will be found!
>> Guillaume
>> Message: 2
>> Date: Thu, 24 Apr 2014 21:43:43 +0200
>> From: Mateusz ?oskot <mateusz at loskot.net>
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
>> Message-ID:
>> <CABUeae-w_cXrPh_jP3oHBKKaqE9sMi+0bG1zdapOcenpXmqW4w at mail.gmail.com>
>> Content-Type: text/plain; charset=UTF-8
>> On 24 April 2014 21:19, Guillaume Drolet <droletguillaume at gmail.com>
> wrote:
>>> I tried the same command as in my previous post on my PC at home.
>>> It's Windows 7 64bit as well and the cluster has the same locale
>>> ('French.Canadian.1252'.) and encoding (UTF8).
>>> The command was successful so my work colleague and I, who
>>> experiences the same behaviour as the one described previously on
>>> this list, suspect that it may be due to some problems or conflict
>>> between PostGIS and the hardware (we have similar systems): is this a
>>> sensible hypothesis?
>> I doubt it. I use raster2pgsql frequently on Windows, since PostGIS
>> pre-2.0 and I have never experienced any such issues.
>> raster2pgsql is a standalone command line utility that generates SQL
>> commands and outputs them to stdout.
>> raster2pgsql has no run-time dependency on PostgreSQL or PostGIS.
>> First thing to check is: does raster2pgsql generate valid output, if
>> redirected to file, does the SQL commands in output file look
>> well-formed and complete?
>> If not, which SQL lines are broken?
>> Do the broken lines correspond to any character data in non-ASCII
> encodings?
>> For example, check if you run raster2pgsql with -F switch to add
>> column with the name of your raster file and the raster file name
>> contains characters with French accents, etc.
>> I'd suggest, don't use psql.exe or load any data to PostgreSQL until
>> you confirm raster2pgsql generates text output with complete
>> well-formed and valid SQL commands first.
>> Best regards,
>> Mateusz ?oskot, http://mateusz.loskot.net
>> End of postgis-users Digest, Vol 146, Issue 28
> End of postgis-users Digest, Vol 147, Issue 1
