[postgis-users] raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR:erreur de syntaxe
Paragon Corporation
lr at pcorp.us
Fri May 2 17:50:49 PDT 2014
Guilliaume,
We maintain the windows build. Sounds like it's the actual library itself
and not the data path that is culprit here.
The only reason I can think why this would happen is if your libgdal build
is also called libgdal-1.dll and for some reason it is further up the PATH
food chain than the one we package. I always thought that PostgreSQL is
configured
To look in bin first and that any files in same folder (raster2pgsql), would
look for their mates in the same folder before looking elsewhere.
I think the visual studio compiled ones are without the lib in front and
have various other dependencies, so they wouldn't even be loadable by the
raster2pgsql.exe/rtpostgis-2.1.dll so are a non-issue.
How is your GDAL 1.11dev built or if you don't build yourself, what
distribution are you using?
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
Sent: Friday, May 02, 2014 3:48 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] raster2pgsql 2.1.1 on Windows 7 64bit -
Regina,
When I do
SELECT postgis_full_version();
It says (from what I remember. I won't have access to my database until next
week) :
GDAL 1.11dev (of course if my 1.11dev installation is at the place described
by the GDAL variable). If my GDAL installation is moved as I did in my
previous post, the GDAL version shown by SELECT postgis_full_version(); is
1.10.
So it looks like a problem with raster2pgsql and rather than with PostGIS as
the loading of the SQL file from raster2pgsql runs fine. I don't know who
maintains this program but maybe it'd be worth checking it against versions
of GDAL after 1.10.
Regards,
Guillaume
> Message: 2
> Date: Wed, 30 Apr 2014 21:24:06 -0400
> From: "Paragon Corporation" <lr at pcorp.us>
> To: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on
> Windows 7 64bit - ERREUR: erreur de syntaxe
> Message-ID: <B32609B07B7A4065BCB2823C48B3F6C5 at O>
> Content-Type: text/plain; charset="us-ascii"
> Guillaume,
> It was my understanding that PostGIS only uses the libgdal in the same
> folder as raster2pgsql since that would be the first in its path.
> However it uses the environment variable for the proj files and so
> forth. So I'm still a bit surprised this is an issue unless those
> files are vastly different from 1.10.
> When you do
> What does it give for the GDAL version.
> If its just a during load problem, I think you can just simply
> override the environment variable in your loader batch script
> SET GDAL_DATA="C:\Program Files\PostgreSQL\9.3\gdal-data"
> Of course this won't fix your running install. In PostGIS 2.2 we
> introduced a PostgreSQL GUC variable to handle this:
> http://postgis.net/docs/manual-dev/postgis_gdal_datapath.html
> But unfortunately that won't help you for 2.1 and not sure how much
> that helps with raster2pgsql anyway since I don't think raster2pgsql
> makes connection to Postgres to be able to even see that variable.
> What I could do is create a build that uses the newer GDAL to see if
> that improves your situation (you can be my test guinea pig :) ). IN
> 2.2 I plan to ship with GDAL 1.11 and probably upgrade next 2.1 to
> GDAL 1.11 as well since unfortunately they have to share the same GDAL
> on same PostgreSQL install and some people I expect will be running both.
> Opinions?
> Regina
> From: postgis-users-bounces at lists.osgeo.org
> Drolet
> Sent: Wednesday, April 30, 2014 4:39 PM
> Subject: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7
> 64bit
> Hi Regina and others:
> We found the problem with raster2pgsql! It was my version of GDAL
> (1.11dev) that my GDAL environment variable was pointing to that
> created the bug. I simply moved my GDAL folder to some other location
> (without changing GDAL environment variable) and ran raster2pgsql
> again so that PostGIS could use its own GDAL instead. This resulted in
> a complete (i.e. no broken line at the end) output SQL file from
raster2pgsql.
> Since I want to keep using my GDAL version (1.11dev, with all my
> add-ons compiled and the version used by other software), this raises the
question:
> how to force PostGIS to not use the GDAL installation referenced by
> the GDAL environment variable but instead use its own GDAL?
> Thanks!
> G
> 2014-04-30 15:00 GMT-04:00 <postgis-users-request at lists.osgeo.org>:
>> Send postgis-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> postgis-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of postgis-users digest..."
>> Today's Topics:
>> 1. Re: Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit -
>> ERREUR: erreur de syntaxe (Paragon Corporation)
>> Message: 1
>> Date: Tue, 29 Apr 2014 18:51:16 -0400
>> Message-ID: <40C3ECB89B9F4C388A6CE0F390D877C5 at O>
>> Guillaume,
>> Did you say this works fine on your home pc, but not your work one?
>> I'm wondering if maybe its some malware or virus checker shutting
>> down the execution of raster2pgsql for some reason.
>> Have you looked at the windows event viewer to see if it is showing
>> any messages? I recall one time a behind the scenes VMWare virus
>> checker kept on deleting some of my Msys files because it thought it
>> was hacker ware. No duh. Had to tell sysadmins to exclude the folder
>> from
> their checking.
>> Hope that helps,
>> Regina
>> Drolet
>> Sent: Monday, April 28, 2014 2:30 PM
>> 64bit
>> Hi Mateusz,
>> Thanks for helping. What you suggested, i.e. outputting raster2pgsql
>> to an SQL file instead of piping it to psql, I have done already. I
>> also posted examples of where the lines are broken in previous post
>> (see also Jean-Daniel Sylvain's older post on the same topic).
>> It doesn't seem to break on non-ASCII characters. For example, this
>> one breaks in the middle of the file name at line 168:
>> INSERT INTO "mod09a1.a2000049.h12v04.005.2006268184041_sur_refl_b01"
>> ("rast","filename") VALUES
>> ('0100000100A544B7031A11713FA544B7031A1171BF86BE196C857752C095AFEE8CE
>> E
>> 6E4740
>> 00000000000000000000000000000000E610000032001F008700000000004D4F44303
>> 9
>> 41312E
>> 41323030303034392E6831327630342E3030352E323030363236383138343034315F7
>> 3
>> 75725F
>> 7265666C5F6230312E74696600'::raster,'MOD09A1.A2000049.h12v04.005.2006
>> 2
>> 681840
>> 41_sur_refl_b01.tif');
>> ('0100000100A544B7031A11713FA544B7031A1171BF59D7C60F306A52C095AFEE8CE
>> E
>> 6E4740
>> 9
>> 41312E
>> 3
>> 75725F
>> 2
>> 681840
>> ('0100000100A544B7031A11713FA544B7031A1171BF2BF073B3DA5C52C095AFEE8CE
>> E
>> 6E4740
>> 9
>> 41312E
>> 3
>> 75725F
>> 2
>> 681840
>> Or, this one (same tif file; I only shortened the filename) breaks in
>> the middle of a cell (or tile?) representation, still at line 168:
>> INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
>> E
>> 6E4740
>> 9
>> 41312E
>> 41323030303034392E7375725F7265666C5F6230312E74696600'::raster,'MOD09A
>> 1
>> .A2000
>> 049.sur_refl_b01.tif');
>> INSERT INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename")
>> VALUES
>> E
>> 6E4740
>> 9
>> 41312E
>> 1
>> .A2000
>> VALUES
>> E
>> 6E4740
>> 9
>> 41312E
>> 1
>> .A2000
>> VALUES
>> This is VERY frustrating and I hope an answer will be found!
>> Guillaume
>> Message: 2
>> Date: Thu, 24 Apr 2014 21:43:43 +0200
>> From: Mateusz ?oskot <mateusz at loskot.net>
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
>> Message-ID:
>> <CABUeae-w_cXrPh_jP3oHBKKaqE9sMi+0bG1zdapOcenpXmqW4w at mail.gmail.com>
>> Content-Type: text/plain; charset=UTF-8
>> On 24 April 2014 21:19, Guillaume Drolet <droletguillaume at gmail.com>
> wrote:
>>> I tried the same command as in my previous post on my PC at home.
>>> It's Windows 7 64bit as well and the cluster has the same locale
>>> ('French.Canadian.1252'.) and encoding (UTF8).
>>> The command was successful so my work colleague and I, who
>>> experiences the same behaviour as the one described previously on
>>> this list, suspect that it may be due to some problems or conflict
>>> between PostGIS and the hardware (we have similar systems): is this
>>> a sensible hypothesis?
>> I doubt it. I use raster2pgsql frequently on Windows, since PostGIS
>> pre-2.0 and I have never experienced any such issues.
>> raster2pgsql is a standalone command line utility that generates SQL
>> commands and outputs them to stdout.
>> raster2pgsql has no run-time dependency on PostgreSQL or PostGIS.
>> First thing to check is: does raster2pgsql generate valid output, if
>> redirected to file, does the SQL commands in output file look
>> well-formed and complete?
>> If not, which SQL lines are broken?
>> Do the broken lines correspond to any character data in non-ASCII
> encodings?
>> For example, check if you run raster2pgsql with -F switch to add
>> column with the name of your raster file and the raster file name
>> contains characters with French accents, etc.
>> I'd suggest, don't use psql.exe or load any data to PostgreSQL until
>> you confirm raster2pgsql generates text output with complete
>> well-formed and valid SQL commands first.
>> Best regards,
>> Mateusz ?oskot, http://mateusz.loskot.net
>> End of postgis-users Digest, Vol 146, Issue 28
> End of postgis-users Digest, Vol 147, Issue 1
