[postgis-users] Geometry vs Linestring
Pier Lorenzo Marasco pl.marasco at gmail.com
Wed May 7 06:38:45 PDT 2014
Hi all,
I'm trying to make something very easy but I've a problem with results.
I've two tables and I need to make lines from the joins of these two. I've
try with this :
CREATE TABLE "l_506" AS
SELECT elements.oid, ST_MakeLine(seeds.geom) AS geom
FROM elements
    JOIN seeds ON (elements.oid=seeds.oid)
WHERE elements.code='0506'
GROUP BY elements.oid;
All the elements in seeds are linestring but what I achieve is a geometry
table. Ok.. I should alter the column type and everything goes as I aspect
but I would like to understand where I'm getting wrong.
L.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140507/8f94465f/attachment.html>
