[postgis-users] Geometry vs Linestring
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 7 06:56:45 PDT 2014
Linestrings are geometry objects. If you want your table to have tighter
constraints on it create the table first and use addgeometrycolumn() to
set the geometry type and constraints then use
insert into "l_506" (oid, geom) from SELECT ...
CREATE TABLE AS does not know what the query will return as far as
geometry types so it make a general "geometry" column.
-Steve
On 5/7/2014 9:38 AM, Pier Lorenzo Marasco wrote:
> Hi all,
> I'm trying to make something very easy but I've a problem with results.
> I've two tables and I need to make lines from the joins of these two.
> I've try with this :
> CREATE TABLE "l_506" AS
> SELECT elements.oid, ST_MakeLine(seeds.geom) AS geom
> FROM elements
> JOIN seeds ON (elements.oid=seeds.oid)
> WHERE elements.code='0506'
> GROUP BY elements.oid;
> All the elements in seeds are linestring but what I achieve is a
> geometry table. Ok.. I should alter the column type and everything goes
> as I aspect but I would like to understand where I'm getting wrong.
> L.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
