[postgis-users] Problems with an update query
Åsmund Tokheim
asmundto at gmail.com
Fri May 9 10:26:18 PDT 2014
Hi
Try your queries using sql explain statements (
http://www.postgresql.org/docs/current/static/sql-explain.html). You should
then be able to see if the postgresql query planner chooses a different
strategy to process your queries. I suspect that postgresql isn't able to
prefilter on gid when you use gid < 10, and instead computes all rows and
at the very end filters out rows with gid less than 10. Use ST_DWITHIN with
a reasonable distance (to stop cross joining the entire table) together
with a gist index on your geometries if you want increased performance.
Åsmund
On Fri, May 9, 2014 at 6:56 PM, Humberto Cereser Ibanez <
humberto at pastoraldacrianca.org.br> wrote:
> On Fri, 2014-05-09 at 17:17 +0100, Alexandre Neto wrote:
> > Hello all,
> > I'm trying to update a table of polygons with the distance to the
> > nearest polygon in the same table and of the same class. I suspect
> > that there is something fishy about the way my query is build.
> > I was using something like this:
> > UPDATE cosc.cosn1
> > SET enn = c.ENN
> > FROM (SELECT DISTINCT ON(g1.gid) g1.gid As ref_gid,
> > ST_Distance(g1.geom,g2.geom) As ENN
> > FROM "cosc"."cosn1" As g1, "cosc"."cosn1" As g2
> > WHERE g1.gid < g2.gid AND g1.class = g2.class
> > ORDER BY g1.gid, ST_Distance(g1.geom,g2.geom)) as c
> > WHERE gid = c.ref_gid;
> May be it is better to make a buffer on g1.geom and filter the g2.geom
> that touch this buffer. For reduce your computation on ST_Distance.
> > It's was taking a long time, but that wasn't surprising. I got my
> > results in 150000ms.
> > While doing some tests I tried no narrow the query a bit by specifying
> > the gid of a feature in the bottom WHERE statement (of the update).
> > UPDATE cosc.cosn1
> > SET enn = c.ENN
> > WHERE gid = 2 AND gid = c.ref_gid;
> > Also not surprising, this took a lot less, around 300ms
> > What started to bug me was the fact that using a different condition
> > to narrow the query by only updating 10 features...
> > UPDATE cosc.cosn1
> > SET enn = c.ENN
> > WHERE gid < 10 AND gid = c.ref_gid;
> > It needed 147510ms to show the results, almost the same as updating
> > the all table!
> > Even more weird was the fact that if I manual set gid = x from [1,10]
> > none of the queries toke more that 400ms to perform.
> Did you create a index for gid (btree) and geom (gist)?
> > Therefore, I must do something wrong for sure!
> > Thank you for your help,
> > Alexandre Neto
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140509/ff5d2e84/attachment.html>
