[postgis-users] ST_MakeLine() woes
georgew
gws293 at hotmail.com
Sun May 11 04:04:40 PDT 2014
Thank you Hugues (and my apologies for using the wrong name), if I understood
you correctly this is what the code should look like:
WITH line AS
(SELECT geom from foot_cl where (sheet='AT24' AND sid=463)),
cells AS
(SELECT ST_Centroid((ST_Intersection(at24.rast, line.geom)).geom) AS geom,
(ST_Intersection(at24.rast, line.geom)).val AS val
FROM at24, line
WHERE ST_Intersects(at24.rast, line.geom)),
points3d AS
(SELECT ST_SetSRID(ST_MakePoint(ST_X(cells.geom), ST_Y(cells.geom), val),
2193) AS geom
FROM cells, line ORDER BY ST_Distance(ST_StartPoint(line.geom), cells.geom))
SELECT ST_MakeLine(points3d.geom) FROM points3d,line,cells
The result is exactly the same as before as you can see here:
makeline.png <http://postgis.17.x6.nabble.com/file/n5006270/makeline.png>
But it should look as follows (after replacing makeline with the points):
points.png <http://postgis.17.x6.nabble.com/file/n5006270/points.png>
Thank you for your help
View this message in context: http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266p5006270.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
