[postgis-users] ST_MakeLine() woes
Hugues François hugues.francois at irstea.fr
Sun May 11 04:30:14 PDT 2014
I don't  have any available data and not enough time for now but you may try the same query but without all "with" statements for the final one ( SELECT ST_MakeLine(geom)  FROM points3d).  You can also add a serial column in the points3d with to keep the ordering information.
Hug
Le 11 mai 2014 13:05, georgew <gws293 at hotmail.com> a écrit :
> Thank you Hugues (and my apologies for using the wrong name), if I understood
> you correctly this is what the code should look like:
> WITH line AS
> (SELECT geom from foot_cl where (sheet='AT24' AND sid=463)),
> cells AS
> (SELECT ST_Centroid((ST_Intersection(at24.rast, line.geom)).geom) AS geom,
> (ST_Intersection(at24.rast, line.geom)).val AS val
> FROM at24, line
> WHERE ST_Intersects(at24.rast, line.geom)),
> points3d AS
> (SELECT ST_SetSRID(ST_MakePoint(ST_X(cells.geom), ST_Y(cells.geom), val),
> 2193) AS geom
> FROM cells, line ORDER BY ST_Distance(ST_StartPoint(line.geom), cells.geom))
> SELECT ST_MakeLine(points3d.geom)  FROM points3d,line,cells
> The result is exactly the same as before as you can see here:
> makeline.png <http://postgis.17.x6.nabble.com/file/n5006270/makeline.png>
> But it should look as follows (after replacing makeline with the points):
> points.png <http://postgis.17.x6.nabble.com/file/n5006270/points.png>
> Thank you for your help
> View this message in context: http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266p5006270.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
