[postgis-users] add foreign-key constraint on raster import
Max Demars
burton449geo at gmail.com
Wed May 14 08:18:40 PDT 2014
I was thinking about this way to do it, but my app has many users, and in
case two rasters with the same filename are loaded, there would be a
problem using filename to create a foreign key. The aim of the foreign key
here would be to specify which user is the owner of which raster.
I suppose I could find a way to handle the possibility of two rasters with
the same filename, but if I could create the foreign key during the import,
I think that would be the best.
On Wed, May 14, 2014 at 11:08 AM, Jason Mathis
<jmathis at redzonesoftware.com>wrote:
> That what I was thinking too. Just to clarify its a capital “-F”.
> Its a handy option for post processing the files in the db.
> http://postgis.net/docs/using_raster_dataman.html#RT_Raster_Loader
> On May 14, 2014 at 9:04:32 AM, Pierre Racine (pierre.racine at sbf.ulaval.ca)
> wrote:
> You can add the filename as a new column with the -f option. Then you can
> extract whatever you want from this column to build a key.
> Does this works for you?
> Pierre
> > -----Original Message-----
> > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> > bounces at lists.osgeo.org] On Behalf Of Max Demars
> > Sent: Wednesday, May 14, 2014 10:08 AM
> > To: postgis-users at lists.osgeo.org
> > Subject: [postgis-users] add foreign-key constraint on raster import
> > Hi,
> > I want to import many rasters from files into a same tablewith a
> foreign-key
> > constraint to be able to query them individually or grouped as needed.
> > I was hopping that the raster2pgsql tool would be able to do it, but no
> > chance.
> > Is there a way to ask raster2pgsql to add a foreign-key during import?
> If
> > not, what would be the best approach for this purpose?
> > Thank you very much,
> > -Max Demars
> > Stack Overflow: http://stackoverflow.com/users/1914034/burton449
> > GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
> > LastFm: http://www.lastfm.fr/user/burton449
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> This transmission contains confidential and privileged information
> intended solely for the party identified above. If you receive this message
> in error, you must not use it or convey it to others. Please destroy it
> immediately and contact the sender at (303) 386-3955 or by return e-mail
> to the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140514/93b41069/attachment.html>
