[postgis-users] problem with st_makevalid and (LineString)
Rémi Cura
remi.cura at gmail.com
Sat May 17 10:21:00 PDT 2014
Hey,
I gave you the 2 queries that eitehr inspect your data or insert only
polygon into your column.
As said previously, there is no "magic function".
Cheers,
Rémi-C
2014-05-17 19:01 GMT+02:00 Åsmund Tokheim <asmundto at gmail.com>:
> Hi
> Use something like
> SELECT st_astext(the_geom), st_astext(st_makevalid(the_geom))
> FROM ft_potencial
> WHERE st_geometrytype(st_makevalid(the_geom)) NOT ilike 'st_polygon'
> to inspect the rows that caused the initial errors. You can also use the
> WHERE-part in qgis, or in a DELETE statement to drop the rows (but please
> try the select statement first).
> Åsmund
> On Sat, May 17, 2014 at 6:52 PM, <islanis at infomed.sld.cu> wrote:
>> "Ivan Santiago" <isantiago at ogp.pr.gov> escribió:
>> Hello there.
>>> I know this forum is about postgis but sometimes you can use another
>>> open source solutions.
>>> You can use QGiS or even better GRASS to clean topological errors.
>>> Sometimes graphic tools work better for this kind of problems...
>> but the table ft_potencial is big, please how can i do it with qgis or
>> grass, have you the steps without it render the entire layer, because i
>> repeat , tha layer is big, i have qgis v1.8.0.
>> thanks
>>> Sent from my Windows Phone
>>> ________________________________
>>> From: islanis at infomed.sld.cu
>>> Sent: 5/17/2014 12:12
>>> To: postgis-users at lists.osgeo.org
>>> Subject: Re: [postgis-users] problem with st_makevalid and (LineString)
>>> "Åsmund Tokheim" <asmundto at gmail.com> escribió:
>>> Hi
>>>> I don't think that you can expect the st_makevalid function to correct
>>>> the
>>>> underlying problem with your data. As Rèmi said, some geometries in your
>>>> original table might have incorrectly been labeled as polygons when the
>>>> coordinates suggests that they are linestrings. In my eyes, the most
>>>> correct solution would be to remove the Polygon-constraint on the data.
>>>> In
>>>> some applications it might be better to use st_buffer to generate a
>>>> small
>>>> polygon around those linestrings, or even more simply discard those
>>>> rows.
>>>> You have to use your knowledge of the application and the source of the
>>>> data to decide how these geometries should best be handled. Inspecting
>>>> the
>>>> geometries that are turned into linestrings might aid you in finding a
>>>> good
>>>> solution.
>>>> As for the cleanGeometry function, I'm not familiar with it, but it
>>>> seems
>>>> to me like the aforementioned line-polygons would be turned into
>>>> null-values by the st_buildarea function. So just like st_makevalid, it
>>>> isn't a one-liner you can use to make all your problems go away.
>>>> Åsmund
>>> well, I need help because I'm not very good at this in the querys,
>>> following the first advice I'd like eliminate tuples than are not
>>> polygons and find and delete the tuples that have null-values, how can
>>> i do that?
>>> thanks
>>>> On Sat, May 17, 2014 at 4:20 PM, <islanis at infomed.sld.cu> wrote:
>>>> islanis at infomed.sld.cu escribió:
>>>>> "Rémi Cura" <remi.cura at gmail.com> escribió:
>>>>>> Hm,
>>>>>>> you have a table with polygons.
>>>>>>> Obviously some of the polygons are not valid.
>>>>>>> So when you correct some of the polygon, they are transformed to
>>>>>>> line (my
>>>>>>> guess : some of the polygons are wihtout surface, for instance
>>>>>>> POLYGON((0 0
>>>>>>> , 1 1 , 0 0 )) ).
>>>>>>> Now when trying to insert line into polygon column, postgres
>>>>>>> complains.
>>>>>>> You can do 2 things :
>>>>>>> _solve the postgres error, this imply to be sure to update with
>>>>>>> polygons
>>>>>>> _solve the geometry problem, this imply to look a bit into your data
>>>>>>> to
>>>>>>> understand why you have invalid polygon in the first place ..;
>>>>>>> The query I gave you is going to show the invalid polygon and why
>>>>>>> they
>>>>>>> are
>>>>>>> invalid (solving 2.).
>>>>>>> If you just don't care, you can update only when the result is a
>>>>>>> polygon.(this querry is suboptimal)
>>>>>>> UPDATE ft_potencial SETthe_geom=ST_MakeValid(the_geom)
>>>>>>> WHERE GeometryType(ST_MakeValid(the_geom) ) ILIKE '%POLYGON%';
>>>>>>> Cheers,
>>>>>>> Remi-C
>>>>>>> What you're doing is ignoring the lines.
>>>>> But that does not bring problems in the future?
>>>>> I found this function, but do not know if it is recommended use it to
>>>>> correct the problems of geometry. I mean cleangeometry
>>>>> CREATE OR REPLACE FUNCTION cleanGeometry(geom geometry)
>>>>> RETURNS geometry AS
>>>>> $BODY$DECLARE
>>>>> inGeom ALIAS for $1;
>>>>> outGeom geometry;
>>>>> tmpLinestring geometry;
>>>>> Begin
>>>>> outGeom := NULL;
>>>>> -- Clean Process for Polygon
>>>>> IF (GeometryType(inGeom) = 'POLYGON' OR GeometryType(inGeom) =
>>>>> 'MULTIPOLYGON') THEN
>>>>> -- Only process if geometry is not valid,
>>>>> -- otherwise put out without change
>>>>> if not st_isValid(inGeom) THEN
>>>>> -- create nodes at all self-intersecting lines by union the polygon
>>>>> boundaries
>>>>> -- with the startingpoint of the boundary.
>>>>> tmpLinestring := st_union(st_multi(st_boundary(
>>>>> inGeom)),st_pointn(st_boundary(inGeom),1));
>>>>> outGeom = st_buildarea(tmpLinestring);
>>>>> IF (GeometryType(inGeom) = 'MULTIPOLYGON') THEN
>>>>> RETURN st_multi(outGeom);
>>>>> ELSE
>>>>> RETURN outGeom;
>>>>> END IF;
>>>>> else
>>>>> RETURN inGeom;
>>>>> END IF;
>>>>> -- Clean Process for LINESTRINGS, self-intersecting parts of
>>>>> linestrings
>>>>> -- will be divided into multiparts of the mentioned linestring
>>>>> ELSIF (GeometryType(inGeom) = 'LINESTRING') THEN
>>>>> -- create nodes at all self-intersecting lines by union the linestrings
>>>>> -- with the startingpoint of the linestring.
>>>>> outGeom := st_union(st_multi(inGeom),st_pointn(inGeom,1));
>>>>> RETURN outGeom;
>>>>> ELSIF (GeometryType(inGeom) = 'MULTILINESTRING') THEN
>>>>> outGeom := multi(st_union(st_multi(inGeom),st_pointn(inGeom,1)));
>>>>> RETURN outGeom;
>>>>> ELSE
>>>>> RAISE NOTICE 'The input type % is not supported',GeometryType(
>>>>> inGeom);
>>>>> RETURN inGeom;
>>>>> END IF;
>>>>> End;$BODY$
>>>>> LANGUAGE 'plpgsql' VOLATILE;
>>>>>>> 2014-05-16 23:58 GMT+02:00 <islanis at infomed.sld.cu>:
>>>>>>>> Remi i dont understand what do you mean here,
>>>>>>>> You can try to analyze a bit to understand better
>>>>>>>> (for the following I consider your table doesn't contains too much
>>>>>>>>> data)
>>>>>>>>> with the_data AS (
>>>>>>>>> SELECT the_geom, ST_ISValid(the_geom) AS is_valid,
>>>>>>>>> ST_IsValidReason(the_geom)
>>>>>>>>> FROM ft_potencial
>>>>>>>>> SELECT *, ST_AsText(ST_MakeValid(the_geom)) AS corrected_geom,
>>>>>>>>> ST_AsText(the_geom) AS original_geometry, detail.*
>>>>>>>>> FROM the_data, *ST_IsValidDetail*(the_geom) AS detail
>>>>>>>>> WHERE is_valid = false
>>>>>>>>> AND GeometryType(the_geom) ILIKE '%POLYGON%'
>>>>>>>>> My guess : you have an invalid no-area polygon, so the makevalid
>>>>>>>>> function
>>>>>>>>> transform it into a line
>>>>>>>>> ok, but like i say above, i dont understan, please be more
>>>>>>>> specific,
>>>>>>>> please, but thanks
>>>>>>>> Cheers,
>>>>>>>>> Rémi-C
>>>>>>>>> 2014-05-16 18:14 GMT+02:00 <islanis at infomed.sld.cu>:
>>>>>>>>>> Hello:
>>>>>>>>>> Run
>>>>>>>>>>> SELECT PostGIS_full_version();
>>>>>>>>>>> TO know if your installation has GEOS 3.3.0 or above.
>>>>>>>>>>> I get this
>>>>>>>>>> "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6
>>>>>>>>>> March
>>>>>>>>>> 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
>>>>>>>>>> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>>>>>>>>>> Iván Santiago
>>>>>>>>>>> GIS Specialist
>>>>>>>>>>> Information Technologies
>>>>>>>>>>> Office of Management and Budget
>>>>>>>>>>> 787.725.9420 x 2378
>>>>>>>>>>> Calle Cruz 254
>>>>>>>>>>> PO Box 9023228
>>>>>>>>>>> San Juan, PR 00902-3228
>>>>>>>>>>> http://gis.pr.gov
>>>>>>>>>>> -----Original Message-----
>>>>>>>>>>> From: postgis-users-bounces at lists.osgeo.org [mailto:
>>>>>>>>>>> postgis-users-bounces at lists.osgeo.org] On Behalf Of
>>>>>>>>>>> Sent: Friday, May 16, 2014 11:24 AM
>>>>>>>>>>> Subject: [postgis-users] problem with st_makevalid and
>>>>>>>>>>> (LineString)
>>>>>>>>>>> Hello people, i got a problem where i have no idea what can i do.
>>>>>>>>>>> I have this table
>>>>>>>>>>> CREATE TABLE ft_potencial
>>>>>>>>>>> id_dw_ft_potencial integer NOT NULL,
>>>>>>>>>>> id_dw_tipo integer NOT NULL,
>>>>>>>>>>> id_dw_mes integer NOT NULL,
>>>>>>>>>>> id_dw_municipio integer NOT NULL,
>>>>>>>>>>> id_dw_date integer NOT NULL,
>>>>>>>>>>> potencial real NOT NULL,
>>>>>>>>>>> area real NOT NULL,
>>>>>>>>>>> the_geom geometry(Polygon,4326),
>>>>>>>>>>> CONSTRAINT ft_potencial_pkey PRIMARY KEY (id_dw_ft_potencial,
>>>>>>>>>>> id_dw_tipo, id_dw_mes, id_dw_municipio, id_dw_date)
>>>>>>>>>>> WITH (
>>>>>>>>>>> OIDS=FALSE
>>>>>>>>>>> and i want to clean the errors that it has using the function
>>>>>>>>>>> ST_MakeValid in this way
>>>>>>>>>>> update ft_potencial set the_geom=ST_MakeValid(the_geom);
>>>>>>>>>>> but it always return this error
>>>>>>>>>>> ERROR: Geometry type (LineString) does not match column type
>>>>>>>>>>> (Polygon)
>>>>>>>>>>> ********** Error **********
>>>>>>>>>>> (Polygon)
>>>>>>>>>>> Estado SQL:22023
>>>>>>>>>>> what can i do to fix or clean the geometry without problems.
>>>>>>>>>>> please help.
>>>>>>>>>>> thanks
>>>>>>>>>>> This message was sent using IMP, the Internet Messaging Program.
>>>>>>>>>>> Este mensaje le ha llegado mediante el servicio de correo
>>>>>>>>>>> electronico
>>>>>>>>>>> que
>>>>>>>>>>> ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>>>>>>>>> Sistema
>>>>>>>>>>> Nacional de Salud. La persona que envia este correo asume el
>>>>>>>>>>> compromiso
>>>>>>>>>>> de
>>>>>>>>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>>>>>>>>> establecidas
>>>>>>>>>>> Infomed: http://www.sld.cu/
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>>>>>>> electronico
>>>>>>>>>> que
>>>>>>>>>> Sistema
>>>>>>>>>> compromiso
>>>>>>>>>> de
>>>>>>>>>> establecidas
>>>>>>>> electronico
>>>>>>>> que
>>>>>>>> Sistema
>>>>>>>> compromiso
>>>>>>>> de
>>>>>>>> establecidas
>>>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>>>> que
>>>>>> Sistema
>>>>>> compromiso de
>>>>>> establecidas
>>>>> que
>>>>> Sistema
>>>>> compromiso de
>>>>> establecidas
>>> que ofrece Infomed para respaldar el cumplimiento de las misiones del
>>> Sistema Nacional de Salud. La persona que envia este correo asume el
>>> compromiso de usar el servicio a tales fines y cumplir con las regulaciones
>>> establecidas
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140517/bdc37e50/attachment.html>
