[postgis-users] polygons to linestrings
Nicolas Ribot
nicolas.ribot at gmail.com
Fri May 23 03:32:31 PDT 2014
Hi Richard,
You could use st_node on the polygon boundaries to rebuild unique, complete
linestrings:
Boundaries are dumped into linestrings in order to build a Multilinestring
containing all PG boundaries.
st_node is performed on this collection, then result is dumped into
individual lines:
with tmp as (
select (st_dump(st_boundary(geom))).geom
from mytable
) select nexval('seq01') as id, (st_dump(st_node(st_collect(geom)))).geom
from tmp;
If your dataset is big, a cut-by-grid approach could speed up the process.
Nicolas
On 23 May 2014 12:26, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> you have to keep the path of the dumped segments, and carefully choose
> which duplicates to keep, inorder to be able to reconstruct in the right
> order.
> (for the rest I'm referring to this function :
> https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_DumpSegments.sql
> Supposing that your polygon have an unique ID, and that you only consider
> there boundaries (interior ring couldn't be shared as they can't touch the
> boundaries and you said you have no overlaps)
> _convert polygon to boundaries, generating a unique ID per
> polygon/boundaries
> _break each boundaries into segment and keep the path of each segment (for
> instance with my function)
> _now you can remove duplicate, but you have to order the querry so has to
> keep continuous parts
> _Then you can recompose your geometry :
> Here is an example :
> WITH the_geom AS ( --creating a fake geom for test purpose, function
> available here :
> https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/cdb_GenerateGrid.sql
> SELECT row_number() over() AS id, geom
> FROM CDB_RectangleGrid(ST_GeomFromtext('polygon((0 0, 100 0, 100
> 100, 0 100 , 0 0))'), 10,10) AS geom
> ,dmp_seg AS ( --breaking the boundary of polygons into segments. Function
> is available here:
> SELECT id, rc_DumpSegments(ST_Boundary(geom)) as dmpgeom
> FROm the_geom
> ,cleaned_ds AS ( --snapping to grid to avoid precision issue, replace 0.1
> by your alloxed precision
> SELECT id, (dmpgeom).path, ST_SNapToGrid((dmpgeom).geom,0.1) as geom
> FROM dmp_seg
> ,dedup AS ( --deleting the duplicates in the segments, but not randomly :
> provide an order to be able ot reconstruct after
> SELECT DISTINCT ON ( geom ) *
> FROM cleaned_ds
> ORDER BY geom, id, path
> ) --reconstructing lines from segment, but again with the right order
> ,reconstructed_lines AS (
> SELECT id, ST_MakeLine(array_agg(geom ORDER BY dedup.path) ) as geom
> FROM dedup
> GROUP BY id
> ) --simple check, can be suppressed : it should output no row
> SELECT id, geom
> FROM reconstructed_lines
> WHERE st_IsValid(geom) = FALSE
> Cheers,
> Rémi-C
> 2014-05-23 6:05 GMT+02:00 Roxanne Reid-Bennett <rox at tara-lu.com>:
> On 5/22/2014 12:28 PM, Richard Greenwood wrote:
>> I have a polygon table that I want to convert to linestrings without
>> any duplicated (overlapping) linestrings. I'm doing this simply to improve
>> cartography so I'm looking for a quick and dirty approach, avoiding
>> topology if possible.
>> I'm not sure I understand what it is you are attempting to do from this
>> description. I would expect lines going in two directions from each
>> polygon and I just don't know how you would use that to help with "improve
>> cartography".
>> The closest I've gotten so far is to break the polygons boundaries into
>> simple (two vertex) lines and delete all the duplicate lines. Now I'm stuck
>> getting the simple lines back into polylines. Just doing a union of the
>> whole mess isn't getting me individual linestrings.
>> So, crazy "out of the blue" question.. have you considered creating a
>> line (or lines) from the centroids?
>> All this is turning into more steps that I anticipated and I wonder if
>> I'm missing simpler approach?
>> Or maybe describe what your target is? There are a lot of people a lot
>> more knowledgeable than I on this list, and if they haven't answered,
>> perhaps you haven't presented your challenge in a manner that they can
>> address.
>> Roxanne
>> Thanks,
>> Rich
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140523/8f696557/attachment.html>
