[postgis-users] Nearest Neighbor question
Gerry Creager - NOAA Affiliate gerry.creager at noaa.gov
Fri May 23 06:46:27 PDT 2014
The inherent problem is that the point will be arbitrarily specified. I
need to find the 4 points in the table 'sites' (it has label, geom, and
lat, lon columns) closest to an arbitrary point given a lat/lon coordinate
pair.
Or, am I making this harder than I think I am?
Thanks!
gerry
On Fri, May 23, 2014 at 5:49 AM, Micha Silver <micha at arava.co.il> wrote:
>  Use ORDER BY and LIMIT 4 to get the nearest 4 points:
> Assuming your point table is called poi, and it has a 'geom' column, and a
> 'label' column, and "lon' and 'lat' give the coordinates of the starting
> location, then
> SELECT poi.label, ST_Distance(poi.geom, MakePoint(lon, lat)) AS dist
> FROM poi
> ORDER BY dist ASC LIMIT 4;
> On 22-May-14 11:47 PM, Gerry Creager - NOAA Affiliate wrote:
> I need to query a rather smallish database and return 4 points closest to
> a lat/lon (or lon/lat, if you prefer) statement. I've been off-line from
> PostGIS and my skills are worse than rusty right now...
>  Thanks
> Gerry
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
>  “Big whorls have little whorls,
> That feed on their velocity;
> And little whorls have lesser whorls,
> And so on to viscosity.”
> Lewis Fry Richardson (1881-1953)
> This mail was received via Mail-SeCure System.
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Moshav Idan
> D.N. Arava, 86840
> cell: 0523-665918http://www.surfaces.co.il
Gerry Creager
NSSL/CIMMS
405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140523/5f4d316a/attachment.html>
