[postgis-users] Nearest Neighbor question
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 23 06:54:21 PDT 2014
SELECT poi.label, ST_Distance(MakePoint(lon, lat), MakePoint(mylon,
mylat)) AS dist
FROM poi
ORDER BY dist ASC LIMIT 4;
-- or --
SELECT poi.label, ST_Distance(geom, MakePoint(mylon, mylat)) AS dist
FROM poi
where mylon, and mylat are you arbitray point locations.
-Steve
On 5/23/2014 9:46 AM, Gerry Creager - NOAA Affiliate wrote:
> The inherent problem is that the point will be arbitrarily specified. I
> need to find the 4 points in the table 'sites' (it has label, geom, and
> lat, lon columns) closest to an arbitrary point given a lat/lon
> coordinate pair.
> Or, am I making this harder than I think I am?
> Thanks!
> gerry
> On Fri, May 23, 2014 at 5:49 AM, Micha Silver <micha at arava.co.il
> <mailto:micha at arava.co.il>> wrote:
> Use ORDER BY and LIMIT 4 to get the nearest 4 points:
> Assuming your point table is called poi, and it has a 'geom' column,
> and a 'label' column, and "lon' and 'lat' give the coordinates of
> the starting location, then
> SELECT poi.label, ST_Distance(poi.geom, MakePoint(lon, lat)) AS dist
> FROM poi
> On 22-May-14 11:47 PM, Gerry Creager - NOAA Affiliate wrote:
>> I need to query a rather smallish database and return 4 points
>> closest to a lat/lon (or lon/lat, if you prefer) statement. I've
>> been off-line from PostGIS and my skills are worse than rusty
>> right now...
>> Thanks
>> Gerry
>> Gerry Creager
>> NSSL/CIMMS
>> 405.325.6371 <tel:405.325.6371>
>> “Big whorls have little whorls,
>> That feed on their velocity;
>> And little whorls have lesser whorls,
>> And so on to viscosity.”
>> Lewis Fry Richardson (1881-1953)
>> This mail was received via Mail-SeCure System.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Moshav Idan
> D.N. Arava, 86840
> cell: 0523-665918
> http://www.surfaces.co.il
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
