[postgis-users] Nearest Neighbor question
Gerry Creager - NOAA Affiliate
gerry.creager at noaa.gov
Fri May 23 06:58:54 PDT 2014
I'll try this after putting out a few new fires! mylat and mylon are WKT?
Thanks!
gerry
On Fri, May 23, 2014 at 8:54 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> SELECT poi.label, ST_Distance(MakePoint(lon, lat), MakePoint(mylon,
> mylat)) AS dist
> FROM poi
> ORDER BY dist ASC LIMIT 4;
> -- or --
> SELECT poi.label, ST_Distance(geom, MakePoint(mylon, mylat)) AS dist
> FROM poi
> where mylon, and mylat are you arbitray point locations.
> -Steve
> On 5/23/2014 9:46 AM, Gerry Creager - NOAA Affiliate wrote:
>> The inherent problem is that the point will be arbitrarily specified. I
>> need to find the 4 points in the table 'sites' (it has label, geom, and
>> lat, lon columns) closest to an arbitrary point given a lat/lon
>> coordinate pair.
>> Or, am I making this harder than I think I am?
>> Thanks!
>> gerry
>> On Fri, May 23, 2014 at 5:49 AM, Micha Silver <micha at arava.co.il
>> <mailto:micha at arava.co.il>> wrote:
>> Use ORDER BY and LIMIT 4 to get the nearest 4 points:
>> Assuming your point table is called poi, and it has a 'geom' column,
>> and a 'label' column, and "lon' and 'lat' give the coordinates of
>> the starting location, then
>> SELECT poi.label, ST_Distance(poi.geom, MakePoint(lon, lat)) AS dist
>> FROM poi
>> On 22-May-14 11:47 PM, Gerry Creager - NOAA Affiliate wrote:
>>> I need to query a rather smallish database and return 4 points
>>> closest to a lat/lon (or lon/lat, if you prefer) statement. I've
>>> been off-line from PostGIS and my skills are worse than rusty
>>> right now...
>>> Thanks
>>> Gerry
>>> Gerry Creager
>>> NSSL/CIMMS
>>> 405.325.6371 <tel:405.325.6371>
>>> “Big whorls have little whorls,
>>> That feed on their velocity;
>>> And little whorls have lesser whorls,
>>> And so on to viscosity.”
>>> Lewis Fry Richardson (1881-1953)
>>> This mail was received via Mail-SeCure System.
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Moshav Idan
>> D.N. Arava, 86840
>> cell: 0523-665918
>> http://www.surfaces.co.il
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> Gerry Creager
>> NSSL/CIMMS
>> 405.325.6371
Gerry Creager
NSSL/CIMMS
405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140523/43b5f0d5/attachment.html>
