[postgis-users] Indexes
Graham Glanfield
graham.glanfield at geocento.com
Wed May 28 10:29:50 PDT 2014
Hi folks,
I have streaming replication running between one master and a few slaves
(Fedorax_86_64 - PostgreSQL 9.2.6 - POSTGIS 2.1.2).
My application only ever reads from a slave, and I have a couple of
questions with regards to indexes and vacuuming.
It is my understanding (probably incorrect) that any vacuuming executed
on the master gets propagated to the slaves as part of the streaming
replication process.
My main question is if I run a spatial query against a slave the first
time, it may take 3 seconds, then the 2nd time it is near instant (if I
query the same slave), so I'm assuming that the slave index/stats must
be being updated? Vacuum is set to run once per night on the master, so
does this mean that if I ran the query on that slave the next morning,
it would take 3 seconds again?
On a similar point, I have a background process that creates dynamic
spatial queries that I hope will help build up the GIST index, and
increase the speed of users spatial queries, but I don't know whether to
run these queries against the master or on each of the slaves?
Best regards,
Graham
